Old 09-10-2012, 12:51 PM   #1
eagle670
My Ride: 199 323i E46
License Plate Bulbs won't work
I have replace my license plate bulbs with brand new ones and they won't work. The bulb our indicators have been on for over a month, but I can't seem to find the problem. Any ideas?
eagle670 is offline   Reply With Quote
Old 09-10-2012, 02:55 PM   #2
FastHackem
My Ride: E60 M5
I didn't think the license plate bulbs show outages on the display. Maybe you need to look somewhere else. The wiring harness that goes into the trunklid often has problems with wires breaking.
The Mind Is A Terrible Thing.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
FastHackem is offline   Reply With Quote
Old 09-10-2012, 05:00 PM   #3
eagle670
So the license plate bulbs would not trigger the indicator to come on? I didn't know that, Thanks!
Old 09-10-2012, 05:29 PM   #4
MojoJoe
My Ride: leaks fluids
The licence plate bulbs do show a bulb out indication. Like FastHackem said, the wiring going into the trunk lid (through the concertinaed hose) can get pinched. Have you replaced them with LED bulbs by any chance?
MojoJoe is offline   Reply With Quote
Old 09-10-2012, 06:09 PM   #5
bchickness
My Ride: 2000 323i conv
Just Had The Same Issue,Checed And Found 3 Wires Broke And 2 getting Ready,Repaired And Now Fine.
bchickness is offline   Reply With Quote
Old 09-11-2012, 11:48 AM   #6
FastHackem
My Ride: E60 M5
No They dont.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
Old 09-11-2012, 10:23 PM   #7
a32ocasio
My Ride: 2000 323i
license plate light do show!! i had the problem for months ,it was showing and all back lights where working, till I change the plate ones, it when off!
a32ocasio is offline   Reply With Quote
Old 09-18-2012, 04:57 AM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Originally Posted by FastHackem View Post
No They dont. [/IMG]
Yes they do. I have coded cars not to show errors for LED license plate bulbs.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 09-18-2012, 06:19 AM   #9
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Elephant trunk issue...as mentioned.
You won't see the broken wires...they'll be broken from metal fatigue inside the insulation.
Push rubber boot into body (cut ziptie in trunk first)...then yank all the wires apart. The ones that are gone or going will break apart.
Inline splice, solder, shrink tubing (plan ahead!).
Facebook.com/DMAXstandup
Mangofy your E46!
Old 09-18-2012, 10:04 AM   #10
FastHackem
My Ride: E60 M5
Hi Jake, glad some more experienced people chimed in finally. I guess my car has been coded at some point because I have had several basic LEDs (not the ones with resistors built in) in my license plate lights before and never had a bulb out warning, even when they failed.
Is the LED coding (no-error) option available through PA Soft? I just recieved mine this past Saturday so I can check to see if that option is coded in there.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
Old 09-19-2012, 03:24 AM   #11
Solidjake
Zero. Leaks.
Solidjake's Avatar
Yup it is, at least for my car in the lighting coding you will see options to disable hot and cold checks on the bulbs.
Old 04-12-2013, 02:28 PM   #12
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
having this issue. both bulbs went out at the same time. I looked at the elepahnt tube wores. nothign is damaged. any other thoguhts?
*NWS GIF REMOVED*
*GIF REMOVED*
**You make me so horny.- Tim330i **
Old 04-12-2013, 02:33 PM   #13
Solidjake
Zero. Leaks.
Solidjake's Avatar
Griffin, looks like you're in new territory
Anyways, idk if there is a fuse for the trunk lights but give it a look. Do the carriers have any corrosion on them?
Old 04-12-2013, 02:37 PM   #14
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
i had LED ones in there,, they worked great until last night. I went to auto zone nad tried to replace them with just reglar oem ones and it still did not turn on.
No corrosion at all vvery clean. I tried swithcing the LED bulb ddirections to see if the current was going the wrong way, but that did not help. I looked at related fuses, and no luck
*NWS GIF REMOVED*
*GIF REMOVED*
Old 04-12-2013, 03:31 PM   #15
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
Damn. Found the wire
*NWS GIF REMOVED*
*GIF REMOVED*
Old 08-27-2014, 07:04 AM   #16
HR1997
My Ride: BMW 323i
Hi, where did you find your problem?
I'm having the same issue
HR1997 is offline   Reply With Quote
Old 08-31-2014, 11:49 PM   #17
JapanRot325ci
My Ride: 04 E46
check your connection sometimes it can be rusted or corrided making it short circuit
JapanRot325ci is offline   Reply With Quote
