Lighting control module confusion - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-27-2013, 09:44 PM   #1
46driver
My Ride: 330i
Quick backstory: car bought with the tail light ground shorted out, taken to dealer for recall fix. When bought the daytime running lights did not work. Had multiple electrical problems related to K-bus and radio. Radio replaced. BMW mechanic said his system could not read any information from the car, only each component individually. Said the instrument cluster had a fault, as well as the LKM. He replaced the LKM with a model that did not have an "auto" selection. Daytime running lights worked, but come to find out the tail lights did not. Got a used LKM off a 2004 325i, now I have lights on the trunk lid but still no bottom illumination on the rear tail light cluster. Also, with the "used" LKM in the auto headlight position the normal head light and tail lights come on, so the auto and head light position of the switch give the same result. Any ideas would be appreciated.
First Pic: Lights on 2nd Pic:Brakes on 3rd pic: 325i used LKM 4th: new LKM
ID:	497500   Click image for larger version
ID:	497501   Click image for larger version
ID:	497502   Click image for larger version
46driver is offline   Reply With Quote
Old 03-28-2013, 01:44 AM   #2
tnhl1989
My Ride: 02 330xi(RIP),03 ZHP
I would get a bmw scanner to read and try to program your car correctly
tnhl1989 is offline   Reply With Quote
Old 03-28-2013, 09:52 AM   #3
46driver
My Ride: 330i
Can I reprogram at LKM module with a scanner? I thought it was a hardwired piece. I am going to sell this disaster in a few months and am willing to fix what I can but not really keen on reprogramming a car.
Old 03-28-2013, 01:10 PM   #4
DOT.
My Ride: '04 ZHP Sedan
Post a picture your your old LCM vs the new LCM with the software version # seen (white sticker on the top). As long as you get the same or newer LCM, you can reprogram the new "used" LCM for your car.
You can also re-use your switch plate so you can retain your "auto" headlights.
DOT. is offline   Reply With Quote
Old 04-12-2013, 02:57 PM   #5
46driver
My Ride: 330i
The first label is the brand new one I returned that didnt have any tail lights. The second pick is the used LKM I am using that give me tail lights but no daytime running lights or bottom brake lights.
ID:	500099   Click image for larger version
Old 04-12-2013, 05:29 PM   #6
DOT.
You need to have your LCM coded for you vehicle. Read up on NCS Expert & PA Soft or look for a shop may be fanatic in your area that can do that for you.
Too bad you returned the brand new one... I would have bought it off from you.
