Old 04-10-2013, 01:07 PM   #1
echoes
My Ride: 2002 330Ci
Noise through audio input while charging (SOLVED)
I have a 3.5mm input attached to the Business CD changer(cant listen to CDs now). It's a third party adapter.
Audio sounds perfect from iPhone, Android, bluetooth device, etc... UNLESS i have that same player device charging using the cars power. As soon as I plug it in to charge it gives me noise while playing audio.
Now, I'm pretty sure this is a ground loop isolation issue but I don't know the best solution. Anyone have ideas or know a good method for isolating this 12v cig lighter from the cars ground?
echoes is offline   Reply With Quote
Old 04-15-2013, 03:06 PM   #2
echoes
My Ride: 2002 330Ci
Lightbulb Solved this
I bought a "Ground Loop Isolator" for twelve dollars and it was able to eliminate the noise I was getting.
Old 04-15-2013, 04:50 PM   #3
ixtoxi
My Ride: 02 330xi, 88 325iX
Good to hear. I have the same problem. Where did you purchase the item?
ixtoxi is offline   Reply With Quote
Old 04-15-2013, 07:09 PM   #4
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
I don't know which one the OP bought, but, I've used this one with success.
http://www.parts-express.com/pe/show...number=265-012
The only problem with ground loop isolators though is they use isolation transformers and their frequency response is not flat from 20-20kHz. Use one of these only as a last resort (or to get you by until the problem can properly be corrected).
scottjoh is offline   Reply With Quote
Old 04-15-2013, 07:45 PM   #5
echoes
My Ride: 2002 330Ci
I bought this one.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
android, audio, business cd, charging, rca
