E46 Convertible
Old 05-18-2011, 05:56 AM   #1
E46DrEaMeR
My Ride: 2004 330ci
e46 vert trim panel removal ?
Im replacing the parts in the pic below but not sure where the screws/fasteners are anyone have any ideas? thanx in advance
Its a ragtop thing! you wouldn't understand
E46DrEaMeR is offline   Reply With Quote
Old 05-18-2011, 01:22 PM   #2
cityjohn
My Ride: 2001 M3
I've never had to take that part off but I would start by removing the side panel to make it easier. Look for speaker DIYs to see how to do it.
cityjohn is offline   Reply With Quote
Old 05-18-2011, 02:05 PM   #3
E46DrEaMeR
My Ride: 2004 330ci
thanx thats what i did in the end
Old 05-18-2011, 05:29 PM   #4
muly
My Ride: 330 sport vert
You have to remove the rear panel, which is easy enough and the part you want is held in by 2 screws, i removed mine last month when i 2 toned my trim
Here's a link that may help
http://bmwfans.info/parts/catalog/E4...im_panel_rear/
muly is offline   Reply With Quote
Old 05-19-2011, 12:15 PM   #5
cjparky
My Ride: 330ci convertible
These parts have disappeared on my vert? Put the roof down and they were there as always no gap, next time the weather was good I had the roof down, happy as Larry, and then noticed they had gone? WTF?! have they come loose and fallen somewhere?
cjparky is offline   Reply With Quote
Old 05-20-2011, 02:00 PM   #6
Duke2080
My Ride: 2001 330ci comv.
Those little covers slide back and forth as the top goes up and down. There is a spring that attaches from the little cover over to a tab on the metal top frame. Your spring probably broe or popped off, so the little cover doesn't get pulled over to fill in the gap. If you reach doen into the gap the little covers are suppose to cover you can feel the covers and slide them up.
Duke2080 is offline   Reply With Quote
Old 05-20-2011, 02:13 PM   #7
fmzip
My Ride: '08 328xi / '01 530i
Great diagram! http://bmwfans.info/parts/catalog/E4...im_panel_rear/
Take of the rear seat, then the arm rests, then the side panel.
fmzip is offline   Reply With Quote
Old 04-16-2013, 07:42 AM   #8
fmzip
Why are the links being blocked???
** SPAM LINK BLOCKED ** Report this post to the moderators [img]images/epc/MTMwODk3X3A=.png[/IMG]
Old 04-16-2013, 03:48 PM   #9
The Thomas J
My Ride: 2002 325Cic
I still need to replace one of those.
The Thomas J is offline   Reply With Quote
