Thread Tools Search this Thread Rating: Thread Rating: 102 votes, 5.00 average. Display Modes
Old 04-17-2013, 03:38 PM   #41
BringsMeWomen
My Ride: 2001 330ci
Great thread. I will forsure use this when im doing a makeover on my lighting
BringsMeWomen is offline   Reply With Quote
Old 04-23-2013, 03:12 AM   #42
Silentalero
My Ride: Acura MDX
im looking into option with headlights, but how does it work with the FXR projector mod if I have the self leveling headlights? with cutting and fitting will that mess with the install? Or am i outta luck with having em.
~ 06 330ci Vert
+ 97 240sx S14 (SR20DET)
- 01 Suzuki Gsxr 750
Silentalero is offline   Reply With Quote
Old 04-23-2013, 03:47 AM   #43
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
That I am not sure about, I would PM Neil1137 and see what he says.
Old 04-23-2013, 12:32 PM   #44
2003atl
My Ride: E90
can i just swap OEM xenon assemblies? with the halogens?
2003atl is offline   Reply With Quote
Old 04-23-2013, 08:45 PM   #45
Neil a.
My Ride: 330i
2003 330i w /factory xenon
Originally Posted by umnitza View Post
wiring up is no big deal, we actually provide adapter cables.
If I want you to upgrade me to more reliable units.drivers side good passenger side needs bulb,modual,& igniter.i want cost for upgrade to both .do you ever send complete units and take mine for cores
?please quote both ways you performing labor or just selling me parts,wiring harness &. All. Thanks,neil
Neil a. is offline   Reply With Quote
Old 04-23-2013, 08:55 PM   #46
Neil a.
My Ride: 330i
Xenon to halogen
Since we have been performing more and more retrofits both on BMWs and other cars, please allow us to reply.
Hopefully this answered your questions, and this guides you better. For more information, please call us or email.
Will xenon wiring work with halogen lights? I may wish to just go with new housings halogen.
Old 04-23-2013, 09:04 PM   #47
umnitza
8774866489
umnitza's Avatar
My Ride: E39M5, Sequoia
Sure thing Neil,
We'd be happy to do that for you. Please give us a call tomorrow 925 521 0577
Old 05-07-2013, 02:54 AM   #48
m_cubed
My Ride: 2005 BMW M3
Sorry in advance if I am derailing this thread, but I have a question which pertains to the original post: I was never aware that there were two varieties of Xenon headlights equipped from the factory. How would I go about identifying which version I have?
m_cubed is offline   Reply With Quote
Old 05-07-2013, 12:01 PM   #49
umnitza
8774866489
umnitza's Avatar
You likely have the standard AL headlights for your M3 that are the same as the 2002-2003 Coupes with the slight difference in where the ballasts are mounted for the M3.
Old 05-07-2013, 03:06 PM   #50
m_cubed
Thank you for the information! Now to get my hands on some clear lenses, I miss the crisp cutoff from my old retros.
Old 05-07-2013, 04:38 PM   #51
My Ride: Lexus
Chris Brown Mod -Painted Bowls OK or NOT ok? Vote:
http://forum.e46fanatics.com/showthr...8#post15405278
Old 05-11-2013, 10:19 AM   #52
halo0
My Ride: '02 330i 5mt
Originally Posted by Solidjake View Post
Morimoto H1 Projector retrofit is a plug and play application for halogen lights which can be done at the cost of around $255 before shipping cost for the projectors, bulbs and ballasts. For $30 more you can get the H1 wiring harness which I recommend. WWW.THERETROFITSOURCE.COM
- Morimoto H1 Mini Projector with bulbs $145
- Morimoto 35 watt ballasts $110
- H1 wiring harness $30
I bought all the parts that you recommended, but I'm confused by the wiring harness and can't seem to find any info on exactly how to install it. I want to make sure I got the right one. The harness has 4 leads coming out from the relays.
1.) Positive wire with fuse, self-explanatory (no pic)
2.) Not sure. Is this the harness's signal input from the car? If so, where do I plug this in?
3 and 4) I'm assuming these plug into the ballasts and I attach each one's ground lead to their own separate ground near that headlight...
Entire harness:
^Click, stop by and say hi.^ ------ 5% off Redline leather
halo0 is offline   Reply With Quote
Old 05-11-2013, 10:51 AM   #53
M-Spec Tuner
My Ride: 325i
You plug pic 2 into your original light bulb connector. Use your best judgement for polarity based on the wire's color. Pic 3-4 do plug into the ballasts.
'03 325i...Just getting started!
M-Spec Tuner is offline   Reply With Quote
Old 05-11-2013, 10:59 AM   #54
halo0
Oh so do I just remove the spade thing and plug it into one of the original low beam plugs? Does it matter which one?
and why did they include those weird spade connectors already on there? just to confuse me!?
Old 05-11-2013, 11:08 AM   #55
Solidjake
Zero. Leaks.
Solidjake's Avatar
THis
Old 05-11-2013, 11:11 AM   #56
halo0
Thanks. For some reason it didn't dawn on me that I had to remove that part from the harness. I was thinking it had to go to the fuse box or something.
Old 05-11-2013, 12:32 PM   #57
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
What kind of ballast would I need if I am going to be doing FX-R 3.0 projectors, E46-R shrouds, and D2 lights?
lllRazorlll is offline   Reply With Quote
Old 05-11-2013, 12:50 PM   #58
Solidjake
Zero. Leaks.
Solidjake's Avatar
Get a high quality ballast such as Denso or Matsushita from TRS.
Old 05-11-2013, 12:52 PM   #59
lllRazorlll
Modded ///Member
My Ride: '00 328i
Okay, thanks. What about harness?
Old 05-18-2013, 08:06 PM   #60
halo0
THis
So I got everything installed today including my angel eyes and everything works great excepts my HIDs flicker while driving and I have a bulb out light on the passenger side. :/ I have pa soft, do I need to recode something?
