Old 05-23-2008, 06:41 PM   #1
umdnoodle
My Ride: 2001 BMW 330Ci
Which Thermostat
Im on KO Performance and im not sure which t-stat to buy. How do i find out which is right. I have a 2001 330Ci Automatic and according to the website it is giving me two options...
Number 1
Thermostat with Thermostat Housing, Includes Gasket 97 deg. C. This part is manufactured by: BEHR THERMOT-TRONIK. Applications: 323i E46. See below for more applications!
Applications: 330Ci E46
Number 2
Thermostat with Thermostat Housing, Includes Gasket 79 deg. C. This part is manufactured by: WAHLER. Applications: 530i E39. See below for more applications!
Please help...i have the check engine light on and im 99% sure its my thermostat. Thanks guys for any tips.
umdnoodle is offline   Reply With Quote
Old 05-23-2008, 07:03 PM   #2
GRIDLOCK
My Ride: E36 / E46
Wahler.
Have an EVAP code? Replacing gas cap did not fix? Give me a holler, I can do a smoke test for ya.
GRIDLOCK is offline   Reply With Quote
Old 04-16-2013, 09:00 AM   #3
RMAAS
My Ride: 04 325 CiC 87 K75C
Update for future searchers. My replacement Wahler thermostat started leaking fromt the temperature sensor at 11,000 miles and 1 1/2 years on the car. It only had a 1 year warranty from the supplier. I'm going to try a Behr next.
RMAAS is offline   Reply With Quote
Old 04-16-2013, 10:05 AM   #4
teamdfl
Slow in, slower out
My Ride: 325it
Behr and Wahler are equally terrible in my experience. Unfortunately, all the other aftermarket ones are much worse.
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
Old 04-16-2013, 10:30 AM   #5
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
I havent had a problem with the Wahler thermostats I have used.
I have tried KO in the past, but could never get them to respond to my contact requests. I will never use them.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 04-16-2013, 11:27 AM   #6
paraklas
My Ride: ESS TS2 320ci
That happened on a Behr too.
paraklas is online now   Reply With Quote
Old 04-16-2013, 11:33 AM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Yea, both have their weakness but unfortunately there is no other choice.
Old 04-16-2013, 11:39 AM   #8
bimer21
My Ride: stick 325i
My Wahler give me problems, i should go with the Behr
bimer21 is offline   Reply With Quote
Old 04-17-2013, 08:46 PM   #9
Sansho
My Ride: 2001 325i
My Wahler thermostat has been good for 2.5 years and 26K miles.
Sansho is offline   Reply With Quote
Old 04-17-2013, 09:59 PM   #10
tonykim
My Ride: 2000 328i
The Wahler thermostat I installed started leaking at the gasket after about 12k miles. I bought a Behr unit and noticed that the molded in o-ring was much taller on the Behr unit in comparison to the Wahler. So far the Behr has gone 25k and no issues.
2000 328 Sport/Premium Pkg, 2005 Ford F150 FX4 SuperCrew, 1993 Ford Mustang LX 520 hp EFI stroker - sold, 1989 Mustang Saleen 450 hp vortech 302, 1978 Pontiac Firebird, 1969 Opel Kadett Rallye ex-SCCA car
tonykim is offline   Reply With Quote
Old 04-17-2013, 10:01 PM   #11
Iggy27
My Ride: 2003 330xi
When you mean oring are you talking about the gasket?
Iggy27 is offline   Reply With Quote
Old 04-20-2013, 08:59 AM   #12
tonykim
My Ride: 2000 328i
yes in the automotive cooling system mfg world it's called a molded in o-ring or gasket.
