Horsepowerfreaks Ethanol Z4M build - Page 16 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-30-2013, 02:33 PM   #301
basar13
My Ride: Z4M, R8, 525xd, STI
Scavange pump fixed.
Vanos removed.
Drive by wire removed. The oem ecu problem is solved.
18 lbs has been removed due to removing vanos and dbw. Lets see how bad will my turbo's spool time will be due to removing vanos. Since it is a race car i dont really care about low rpms.
I will open a new thread soon with a video hopefully.
Stay tuned
basar13 is offline   Reply With Quote
Old 03-30-2013, 08:21 PM   #302
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
Vanos removed.
Stay tuned
Would u mind explaining what the drive by wire problem was causing?
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 04-07-2013, 05:01 AM   #303
basar13
Excuse me for the late reply i was out of the country,
As you know, there is a need for a after market ecu when you put a turbo on car. The aftermarket ecu needs to use the crank, cam sensors to know the engines position. So you can do live mapping which you cannot do on oem ecu.
The problem is that unlike m3's ecu Z4M's ecu is more sensitive and it senses that an other ecu is reading the signal. Then it puts the car to safe mode.
When you delete the vanos and delete the drive by wire the oem ecu has no control over the engine so it cannot give you any problem and you control the engine with your aftermarket ecu.
Downside for my application is the horsepower loss in low rpms. So a little delay in spool.
We will continue to work this week...
Old 04-19-2013, 08:33 AM   #304
basar13
The car is finished it runs on 6 psi right now. It is pretty fast. I will record a video and take some pics and open a new thread soon.
Old 04-20-2013, 12:54 PM   #305
Twin_Turbo_S54
My Ride: M3
Congradulations, drive in good health.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 04-20-2013, 12:58 PM   #306
dallasberry
My Ride: ///M3
Good to Hear Lets see some Videos
Custom Turbo Build By Lab22
815whp @ 625wtq 27psi E98
dallasberry is offline   Reply With Quote
Old 04-21-2013, 08:41 AM   #307
BMW E465
My Ride: 1dirty5
How tricky was it to get everything working? Congrats btw.
BMW E465 is offline   Reply With Quote
Old 04-21-2013, 03:26 PM   #308
basar13
Thanks, it is great fun.
Old 04-21-2013, 03:27 PM   #309
basar13
Thanks i will get some videos this week hopefully
Old 04-21-2013, 03:31 PM   #310
basar13
Z4M's ecu is a total problem even the fuel system has its own ecu once you delete vanos and dbw the ecu has no power.
Traction system is disabled right now so does the rpm gauge and oil temp gauge.
i already have installed various temp and pressure gauges so no problem for me.
Old 04-23-2013, 04:38 PM   #311
basar13
I will no longer update this topic.
Here is a second gear run video at 6 psi.
http://www.e46fanatics.com/forum/sho...d.php?t=983642
