Sponsored by BimmerWorld
Old 04-21-2013, 04:29 PM   #1
blue99_328i
My Ride: 1999 328i sedan
help please
just got my 99 e46 4d inspected they told me my front suspension needed to be replaced i asked how much and he said he didn't have a quick quote right away. anybody have an idea of what that runs?
Sent from my N860 using Bimmer App
blue99_328i is offline   Reply With Quote
Old 04-21-2013, 04:31 PM   #2
NOVAbimmer
My Ride: E60M
help please
Well, the first question to ask is what actually need to be replaced? Shocks? Springs? Control arms? Away bar bushings? End links? Everything?
NOVAbimmer is offline   Reply With Quote
Old 04-21-2013, 04:33 PM   #3
blue99_328i
he said everything the whole front suspension so im assuming he meant everything. they were pretty packed so he didn't have much time to explain.
Old 04-21-2013, 07:47 PM   #4
lszlszx
My Ride: 1.8T, XC70
I would be suspicious of a shop that uses blanket statements like that.
Get a 2nd estimate. Some of the work is really easy, no need to pay anybody.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-22-2013, 11:29 AM   #5
blue99_328i
well the problem is that it rattles the steering wheel at 50-70mph and when i brake. he said my suspension was too loose and it could fall out. i honestly didn't think it was that bad on account of him passing me. if it was that bad wound he not fail me? i know for a fact im due for some new springs. idk about the entire front though. I will look into getting a second or even third opinion.
Old 04-22-2013, 05:55 PM   #6
lszlszx
My Ride: 1.8T, XC70
Springs last the life of the car. You probably need control arm bushings, or complete control arms. What is the mileage? Ask them to show you what is worn out with the car on the lift.
Old 04-22-2013, 07:05 PM   #7
blue99_328i
mileage is about 186k mostly driving from tx to Louisiana.
Old 04-22-2013, 07:35 PM   #8
dre8119
My Ride: destroys my wallet
help please
Go to another shop, I'm pretty sure you don't have to get your entire front end replaced..
dre8119 is offline   Reply With Quote
Old 04-23-2013, 06:50 PM   #9
Minnoe07
My Ride: 2004 BMW 330Ci
More than likely control arms and control arm bushings, also known as thrust bushings. Haven't done parts shopping recently but expect around $300 if you shop your own. More if you get the shop to purchase your parts. Don't know how many hours shops charge for the work but I assume it is about a 3 hour job by the book. Multiply that by the shop rate.
Or just go to a shop and get a quote. If you don't like it, go to the next shop.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
