Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 04-23-2013, 07:34 PM   #1441
Foxtrot_Uniform
My Ride: 325Xi
Follow the links on the first page... You should be able to just download the software you need!
Foxtrot_Uniform is offline   Reply With Quote
Old 04-23-2013, 07:37 PM   #1442
nanpat
My Ride: 325i
Diagnotic Scanner
Hi there,
Do you mind if I ask where you bought the scanner and what the cost was. We are in need of one.
Thanks,
nanpat is offline   Reply With Quote
Old 04-23-2013, 07:41 PM   #1443
zx5rider
My Ride: 03 M3 , 03 TT 330,
Send a message via AIM to zx5rider
I see no link for it
Sent from my SCH-I605 using Bimmer App
'03 330 Technique Tuning Stage 2 Turbo. (Parting out)
'03 M3
'11 BMW s1000rr
zx5rider is offline   Reply With Quote
Old 04-23-2013, 07:44 PM   #1444
zx5rider
Nvm thanks
'03 M3
'11 BMW s1000rr
Old 04-28-2013, 04:45 AM   #1445
ronleach
Banned
My Ride: bmw
Send a message via ICQ to ronleach
Check you Package .
Package including:1pc x BMW SCANNER 1.4.0 main unit,1pc x USB Cable,1pc x CD Driver
May be less a
ronleach is offline   Reply With Quote
Old 04-28-2013, 02:14 PM   #1446
headrec
My Ride: 2002 BMW 330ci
Will this work on windows 7 home premium edition 64 bit OS?
headrec is offline   Reply With Quote
Old 04-28-2013, 03:30 PM   #1447
Foxtrot_Uniform
My Ride: 325Xi
Works on mine! Just make sure you turn off wifi when installing per the directions.
Old 04-28-2013, 03:31 PM   #1448
Foxtrot_Uniform
My Ride: 325Xi
You just need to LOOK for it!
Old 04-28-2013, 03:48 PM   #1449
headrec
Old 04-29-2013, 09:20 AM   #1450
SeattleLSB
My Ride: 2003 330XI, 2003 M3
Can anyone help me with Code 21/033 HVAC Front Load Sensor, Open Circuit?
2003 LSB/BLK M3/SMG/Premium/Cold Weather/Nav
2003 AW/BLK 330XI/AT/Sport/Premium/Cold Weather
SeattleLSB is offline   Reply With Quote
Old 04-29-2013, 02:34 PM   #1451
zhenkaaaM3
My Ride: Fst'r then your e46
Re: *OFFICIAL* BMW Diagnostic Scanner PA Soft 1.4 Thread
How do you remove tamper dot?
Put in the correct mileage and it goes away?
Sent from my SGH-T999 using BimmerApp mobile app
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 05-02-2013, 12:56 PM   #1452
chasdude
My Ride: 2000 323I
Can anyone please advise on the codes 22/02 - HVAC, front load sensor, short circuit to ground
24/02 - HVAC, rear load sensor, short circuit to ground. This is on a 2000 323i sedan. I have been going through final stage resistors like crazy?
chasdude is offline   Reply With Quote
Old 05-04-2013, 04:47 PM   #1453
BigDRick323
My Ride: 2000 323i
I am getting "Hardware Not Ready" error, ideas????
Old 05-04-2013, 04:59 PM   #1454
Imanewbie
My Ride: is my crack.
The driver is not installed right or if you have a BMW plug under the hood, you need obdII to BMW adapter.
Imanewbie is offline   Reply With Quote
Old 05-04-2013, 05:01 PM   #1455
Imanewbie
If its pre 6/2000 then you need the adapter. I had a 7/2000 323 and I did not need it, my 5/2000 328 needs the adapter.
This is the one I got.
http://www.amazon.com/gp/aw/d/B0054F...pi=SL500_SX125
Old 05-04-2013, 05:05 PM   #1456
zhenkaaaM3
Old 05-04-2013, 05:13 PM   #1457
Imanewbie
The miles need to be correct, it has to match the backup.
Old 05-04-2013, 05:14 PM   #1458
Imanewbie
You need to use VMware with 64bit.
Old 05-04-2013, 07:44 PM   #1459
zhenkaaaM3
Well. When you hook up the scanner to the car, the vin and mileage show up. Do i take that #, and rewrite the speedometer?
Eugene
Old 05-04-2013, 07:55 PM   #1460
BigDRick323
My Ride: 2000 323i
I have adaptor and never had this problem before.
Sent from my LG-MS870 using BimmerApp mobile app
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
