E46 COOLING SYSTEM GUIDE - overheating/coolant/etc - Page 59 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 420 votes, 4.68 average.
Old 04-21-2013, 05:05 PM   #1161
My Ride: Lexus
Originally Posted by 2shaee View Post
Thank u mango. Only few more questions. Does car need to be on jack stands(front of the car) during this procedure? And what temperature car need to reach while running? After finishing bleeding i mean.
lifting the car helps bleeding. i don't know anything about 318 model temps. sorry.
Old 04-22-2013, 09:03 AM   #1162
2shaee
My Ride: E46 318i
You know what..i'll do my own procedure and than i'll make DIY for M43 engine. BEcause if the engine temperature rise up to 105 degrees there should be different procedure. Mango's DIY is for cars under 100 degrees.
2shaee is offline   Reply With Quote
Old 04-22-2013, 09:11 AM   #1163
TerraPhantm
My Ride: M3 & ZHP
Why would that make a difference? A 50/50 mix will have a boiling point well above 100C
Old 04-22-2013, 09:13 AM   #1164
2shaee
My Ride: E46 318i
We are not talking about mixture. I am talking about M43 engine. And it looks like that this engine reach higher temperature than other one. And it needs special bleeding procedure(when it is hot) otherwise air bubbles will be in system.
Old 04-24-2013, 08:19 PM   #1165
Jmhockey1920
My Ride: 2002 325i
I have a $225 credit at BMAautoparts...has anyone bought all of their cooling overhaul parts from that website? If so, what brand did you get for the WP, ET, and Thermostat? Thanks
Jmhockey1920 is offline   Reply With Quote
Old 04-24-2013, 10:36 PM   #1166
My Ride: Lexus
i should do a mango recommendation list of brands
Sent from my SGH-T999 using Bimmer App
Old 04-26-2013, 03:13 PM   #1167
Japanrot_325i
My Ride: 03 325i
* E46 Cooling Guide (Information w/parts list/bleeding) *
Well mango you seem to be the authority so let me ask you. I'm a little tight on funds lately and I believe my cooling system is stock. What are the most critical components that need replaced. From what I read it's et and water pump but I thought I'd ask. Thanks
Japanrot_325i is offline   Reply With Quote
Old 04-26-2013, 03:17 PM   #1168
My Ride: Lexus
IMO: expansion tank, cap, upper hose (only because you're breaking the original seal by replacing the expansion tank), thermostat, belts and pullies. Fan switch if you have an extra $20 on top of all that.
Should cost you $60 + $10 + $20 + $50 + $10 + $7 + $20 + $20 + $20 + $20 = $237
That's if you're on a tight budget. I honestly wouldn't recommend any less than that at an absolute bare minimum.
Old 04-26-2013, 04:19 PM   #1169
Stinger9
My Ride: '04 330Ci
If you want to stretch things, but make sure you avoid dire fails, you could remove your water pump and make sure you do not have a plastic impeller, nor is the bearing getting sloppy. If you have metal, put it back in with a new O-ring gasket.
Also you can monitor the thermostat operation by using the OBC hidden functions. It you're holding solid around the 95 degrees C level, wait till you see the beginning of a slow fail before you even think about replacing.
Def do the ET!
Got an automatic? Uh-oh!
Old 04-26-2013, 04:21 PM   #1170
My Ride: Lexus
Def do the ET!
The material of the impeller is irrelevant.
Old 04-26-2013, 04:25 PM   #1171
Stinger9
My Ride: '04 330Ci
au contraire mon frere
Old 04-26-2013, 08:18 PM   #1172
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Wrong! You do not want the Red Light of Death with a Plastic Impeller.
ALways go for the Stewart WP or one with the Metal Impeller. Plastic and BMWs do not mix@!!
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptain
BMWCaptain is online now   Reply With Quote
Old 04-26-2013, 10:42 PM   #1173
My Ride: Lexus
no
Old 04-26-2013, 11:21 PM   #1174
BMWCaptain
no
Da!
BMWCaptain
Old 04-27-2013, 01:45 PM   #1175
TerraPhantm
My Ride: M3 & ZHP
I don't think any of the non-M impellers are plastic anymore. It's either metal or composite. The composite is superior; less load on the bearings.
Nothing inherently wrong with plastic either. S54 pump is plastic, and I've never heard of the impeller failing. Bearings on occasion, but that's pretty rare.
Old 04-27-2013, 05:52 PM   #1176
My Ride: Lexus
Correct. I've explained this several times before but newcomers (and even old-timers alike) keep shouting plastic evil plastic evil and try to challenge anything else. It's caveman-like and doesn't look at the big picture.
The current (extremely old--at least a decade) design is plastic composite. For all intents and purpose, we refer to it as "plastic." To people like the above, anything not metal is "plastic" and sucks. Nothing could be further from the truth.
As I've posted in several threads, there are tons of other considerations to take into account when considering a water pump. In the end, all the current designs both OE and aftermarket are great and serve their intended life expectancy and purpose quite well. Not sure why people keep zeroing in on the "plastic water pumps." pretty much every OE E46 pump lasts 100k+ miles.
Nobody should even bring up the word water pump ever except when telling us they ordered a new one. Theres nothing to discuss. It's just another component that needs to be replaced.
Old 04-27-2013, 06:33 PM   #1177
XKxRome0ox
Black and Proud
My Ride: RIP e46/'16 328i
I can testify to the longevity of the original water pump with "plastic" impellers
I just replaced mine after nearly 12 years and 173k miles of service without failure
[bimmerapp]
2016 BMW 328i 6MT/M Sport Package/Track Handling Package/M Performance Exhaust/Injen CAI/Dinan Shockware
XKxRome0ox is offline   Reply With Quote
Old 04-27-2013, 07:56 PM   #1178
Stinger9
My Ride: '04 330Ci
Student of statistical analysis?
That proves it all. Nothing more need ever be said.
Old 04-27-2013, 09:48 PM   #1179
lszlszx
My Ride: 1.8T, XC70
Checked a coolant leak. It's the thermostat I put on a few weeks ago.
The only good news is, at first I thought it was the headgasket.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-27-2013, 10:16 PM   #1180
Stinger9
My Ride: '04 330Ci
Cause was defective gasket?
Or cracked housing?
Or bad seal to hose?
What BRAND did you install?
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
