Old 04-25-2013, 12:01 PM   #1
Kubica
My Ride: 2003 325xi
Autocross Tires for 2013
Thoughts on tires for the upcoming season?
I was hoping to start a discussion based on actual experience, rather than an analysis of Tirerack and C&D reviews.
Possibilities:
A) Dunlop Start Spec 2
B) BFGoodrich Rival
C) Bridgestone RE-11A
Also, what's the deal with the Michelin SuperSports as an autox tire? I have read they are faster than the old Star Specs? Can anyone confirm or deny with actual experience? They weigh several pounds less than the tires listed above, so I am considering them.
I am currently on 235/40/18 Star Specs on BBS RCs and I think I could go faster on a shorter, lighter tire with slightly less grip. Straight line acceleration takes a big hit when I switch out my winter setup (225/45/17 Hakka's on BBS RKs) that weight 4.5 pounds less at each corner. Most of that weight increase is in the tire, and they also stand about 1/2" taller.
Old 04-25-2013, 12:36 PM   #2
murph1379
My Ride: 2006 M3
I think you'll find that the acceleration differences are much more in the gearing (tire height) than the weight. Even in a torqueless car like a miata, it's hard to notice weight differences in lap times. (GRM actually tested this)
I'd recommend a 245/17 or 255/17 on a 9"+ wheel.
murph1379 is offline   Reply With Quote
Old 04-25-2013, 02:20 PM   #3
Kubica
My Ride: 2003 325xi
I have a 8" wide 17" wheel or a 8.5" wide 18" wheel.
A 235/35/18 would be nice but not available. I am leaning toward a 235/40/17.
Interesting question- what's faster on a torque-limited car: 235/40/17 at 24.4" tall or 245/40/17 at 24.7" tall.
Keep in mind I will have to lose some front camber if I go up to a 245 in order to stay in my class. We have 5 BMW autox classes in the Boston BMWCCA and a finely tuned points system to determine which class you run in. If interested, check it out here: http://www.boston-bmwcca.org/Autocro...ification.aspx
Old 04-25-2013, 10:10 PM   #4
katu
My Ride: '04 330ci ZHP
I only have personal experience with Michelin Super Sports for autocross. I like them but I think I am going with the Bridgestone RE-11A next time around. I've been reading a lot and the Super Sport will last longer and do better in the rain, but the RE-11A is a better autocross tire for sure.
katu is offline   Reply With Quote
Old 04-26-2013, 12:21 PM   #5
lejeunebimmer
My Ride: 02' M3 SMG, 02' 330i
Have you considered Hankook RS-3?
330i - AA Tuned, Headers, UUC Stage I LW FW, e36 M3 Clutch, UUC SS Clutch line, BMW Performance Intake, Evo Sport Pulleys, BMW Performance Cross-Drilled Rotors, Hawk HPS, BW SS Brake Lines, BW Solid Guide Bushings, BMW Performance CF Strut Brace, H&R Sways, H&R Sport Springs, Bilstein Sport Shocks, Powerflex Bushings, LED Tails, Clear Sides/Turns, Black Grill, Mtech 2, CF Splitters
M3 - Not enough room to list
lejeunebimmer is offline   Reply With Quote
Old 04-26-2013, 02:08 PM   #6
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
Rival and Direzza ZII will be the top dogs for the season. I have a set of the ZIIs but haven't had a chance to autocross on them yet. Andy Hollis, Terry Fair, and some others have written a lot about the Rival & ZII.
Chris
dreamdrivedrift is offline   Reply With Quote
Old 05-01-2013, 12:01 AM   #7
SK330ci
My Ride: 02 330ci w/ 3 Pedals
OP, are you aloud to run any tire you want in the class you'll be Autocrossing in, like a DOT-R compound ? Or do you need to stay with an actual street tire.
If I had to choose a street tire, I second the Hankook RS-3 suggestion.
If money were no object and you could run a DOT-R spec tire, the absolute best bet would be the Hoosier A6.
Your second choice, and considerably cheaper would be the Hankook Ventus Z214.
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 05-02-2013, 01:50 PM   #8
Kubica
My Ride: 2003 325xi
Treadwear needs to be above 140 to be considered street tires. I don't have enough power/too much weight to compete in the R-comp class. Price is not really the issue. Brand and size are more important.
Right now I'm running -3 degrees camber up front and 235 tires. If I go up to a 245, I'd have to drop down to -2.5 degrees camber. If I go with a 225, I can run -3.5 degrees camber.
Old 05-02-2013, 05:14 PM   #9
Bimmerguy91
My Ride: 2010 328I M Sport
I am a huge fan of the RE-11. I had them on my Genesis Coupe and loved them. I plan to put the new RE-11A's on my Z4MC when I am done wearing out these Continental Extreme Contact DW (crap tires I hate them)
Bimmerguy91 is offline   Reply With Quote
Old 05-02-2013, 05:29 PM   #10
lejeunebimmer
You're the only person I've ever heard say that about those Conti's. Do you use them just for street driving, just Autox, or both? Because I absolutely love them for the street, but I will agree 110% about them being crap on dry Autox/track. Wet they do pretty darn well though...
Old 05-02-2013, 06:52 PM   #11
Bimmerguy91
Just street use mostly. I just think they are noisy and that the grip is not on par with what I am used to. I know these tires aren't even in the same category as the above mentioned tires but still.
Old 05-03-2013, 08:57 AM   #12
shell_guy
My Ride: 2002 M3
AD08 hands down if your allowed to run them, if not i would go RE11a. I am running original RE11's and I really like them.
shell_guy is offline   Reply With Quote
Old 05-03-2013, 11:22 AM   #13
Kubica
My Ride: 2003 325xi
What do you like about the AD08 vs. another choice?
Old 05-03-2013, 11:40 AM   #14
shell_guy
My Ride: 2002 M3
AD08's are the closest thing to a r-comp tire you can get in a street tire. The turn in is fantasic, i find they are really stable and a lot more perdictable on the track. As a street tire they are a bit noisy and wear quickly, but on the track they are fantastic.
Old 05-03-2013, 12:58 PM   #15
dreamdrivedrift
you serious here? ZII, Z1 Star Spec, and Rival > AD08. AD08s are overpriced and do not perform as well as the other ones I mentioned. All the fastest guys at Nationals on street tires are running what I listed
Chris
Old 05-03-2013, 03:16 PM   #16
shell_guy
My Ride: 2002 M3
I did not like the Dunlop z1 when I tried them, found the initial turn in was not as good as my ad08. However the new Rival looks good and I would like to try them. I just wish I knew more people who have tried the Rival on their own cars.
Old 05-04-2013, 01:10 PM   #17
SK330ci
Interesting question- what's faster on a torque-limited car: 235/40/17 at 24.4" tall or 245/40/17 at 24.7" tall......
I've given this a lot of thought. I think after researching this, your answer is your 235/40-17. From a weight, gearing & Neg. camber stand point it's a winner over your other size choices. Brand consideration, well that could still go way few different ways; my choice is still the Hankook RS-3.
Old 05-05-2013, 09:34 AM   #18
dreamdrivedrift
i see, that surprises me as turn-in from both my Z1SS and ZII have been very sharp. Much more so than RS3s. I agree about the Rival...the reason I chose the Z2 is because the Rival's treads do not look like they will be happy in the rain. It looks more like a dry-only tire.
Go for the 17s with the 235s. Why do you have to reduce camber if you run a wider tire? Should be the other way around...run more camber with a wide tire
Chris
Old 05-07-2013, 05:52 PM   #19
murph1379
My Ride: 2006 M3
Ran on the rivals this weekend, LOVED them.
Old 05-08-2013, 08:21 AM   #20
dreamdrivedrift
GRM just released their tire testing article between the ZII and the Rival, with the Toyo R1R as a benchmark. Summary of it is that the Rival is a BOSS! Great tire at all psi, handles heat well, and they are tolerant of large slip angles. The ZII seems to be a more finicky tire that is more setup and heat dependent.
Now I kind of wish I got the Rivals, but nonetheless I can't wait to run my ZIIs in June
Chris
