///M3 Forum
Old 04-24-2013, 07:45 PM   #1
Ballerbrian4u
My Ride: 2004 BMW m3
Smg Adaptaion
Is it bad for the smg to do a smg adaptation every few months?
Ballerbrian4u is offline   Reply With Quote
Old 04-24-2013, 08:15 PM   #2
///M Powerd
My Ride: 2003.5 M3 Coupe
Are u talking about the soft reset or an adaptation using a GT1 tool at the dealership?
///M Powerd is offline   Reply With Quote
Old 04-24-2013, 08:42 PM   #3
Ballerbrian4u
Not the soft reset the one done with a computer.
Old 04-24-2013, 10:52 PM   #4
$ilent ///M
My Ride: 03.5 M3 smg lsb
I don't think it will be bad just doesn't need to be done quite as often. I think I read it should be done I think say about 50k miles
$ilent ///M is offline   Reply With Quote
Old 04-24-2013, 11:15 PM   #5
illestminimike
My Ride: Project Drama
Smg Adaptaion
I don't see any purpose in doing that.
Old 04-25-2013, 03:50 AM   #6
sakumaxp
My Ride: 02 M3 convertible
Smg Adaptaion
What does this "adaptation" do?
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 04-25-2013, 04:15 AM   #7
NumbaOneNewb
My Ride: 2003 330CI Silver
The smg adaptation allows you to synchronize the transmission to the engine. I found this out when I did a euro tune on an 04 m3. Before finding out, after the flash, he technically was able to drive it. After I left, I guest he said he couldn't put it into gear.
Every time he put it into gear, the tranny made a loud clunk, and immediately caused the car to stall. It sounded kind of scarey actually. So in the end, I returned, performed smg adaptation and the car ran great. During the adaptation, the computer bleeds the clutch to purge any air in it. Then it goes through each gear shifting through them all for about 10 minutes. The last step require that you hold the clutch in and start the car.
Sent from my SPH-L710 using Bimmer App
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 04-25-2013, 05:01 AM   #8
Properstyle
My Ride: 2002 SMG M3
Do you have a link with those instructions by chance, I don't remember seeing that in the PDF I down loaded for my car.
My Build..............................................AGT Diffuser group buy
Prince-B
Properstyle is offline   Reply With Quote
Old 04-25-2013, 09:18 AM   #9
choxor
My Ride: JDM
If you're talking about the SMG teach ins then no, there's no point to do it every couple of months. Leave well enough alone. Maybe annually.
Old 04-25-2013, 09:30 PM   #10
msane3
My Ride: 2007 335i
Smg Adaptaion
I would do it every 2-3 months because I have autoenginuity. It helped dramatically with take offs and smoothness of shifts. The self adjusting clutch and the smg system aren't synchronized as well as they should be and it could either over/under compensate for wear and cause jerky acceleration/shifts, clutch take up, etc. I say this from first hand experience.
msane3 is offline   Reply With Quote
Old 04-26-2013, 03:58 PM   #11
grkm3
My Ride: Money Pit
Send a message via AIM to grkm3
I've done it several times without issue. I originally used Autoenginuity but now use INPA as I find it easier to use.
SOLD
03 Steel Gray M3 - Imola Red Interior - SMGII - Premium - HK Sound
Mods: VFE SC Stage 2, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe, TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R brakes
Coming Soon: Open to suggestions
grkm3 is offline   Reply With Quote
Old 04-26-2013, 04:22 PM   #12
choxor
My Ride: JDM
DIY would be awesome
