Old 04-28-2013, 03:32 PM   #1
AquaRelliux
My Ride: 330ci 03 M-sport
So I bent rear left lifting floor now what?
Just as topic says I managed to bend my floor under my lifting blocks by accidentally lifting the car with the jack a bit of the block close to the side skirt. This caused the block to collapse in on the outer side of the block can this be fixed? I can still lift the car fine by lifting it on the side that is not collapsed.
AquaRelliux is offline   Reply With Quote
Old 04-28-2013, 03:54 PM   #2
tootall
My Ride: 2011 328iT 3 pedals
A body shop can access how easy or difficult it is to fix. You have to use the jack points properly or you will bend the unibody. There are quite a few threads on how to jack up the car. Here is one:
http://forum.e46fanatics.com/showthr...288&highlight=
BMWCCA member since 1990
Upgrade your 328 with a 330 intake: http://forum.e90fanatics.com/showthread.php?t=1095889
tootall is offline   Reply With Quote
Old 04-28-2013, 04:42 PM   #3
AquaRelliux
I have jacked the car up millions of times it is jus this time I missed the jack point slightly and it looks like it is going to cost me
Old 04-28-2013, 05:18 PM   #4
2003silver330i
My Ride: 03 BMW 330i
If it didn't put a hole in the floor I wouldn't worry about it. If you can get to the dent from the inside, maybe try to pound it back out.
2003silver330i is offline   Reply With Quote
Old 04-29-2013, 05:07 AM   #5
AquaRelliux
Well there is no hole it is just bent by 1-2cm max, sucks tough that **** like this happens .It is likely possible to bend it back but then there is the problem with metal fatigue which my cause it to bend more easily next time
Old 04-29-2013, 11:50 AM   #6
My Ride: Lexus
i don't agree with that photo/thread.
Old 04-29-2013, 05:42 PM   #7
jaymemaurice
Location: Anchorage Alaska or Kitchener, Ontario, Canada
My Ride: 01 330ci, 03 Passat
This is my explanation of where I jack...
Originally Posted by jaymemaurice View Post
Mine is a 2001 and it has a stamped sort of bump with a re-enforcement underneith about where I circled in red below, jack stands where the green is - I jack it with a low profile floor jack with a rubber pad. It has not deformed:
Rain Sensor Retrofit: Here
Coupe Headline Replacement: Here
jaymemaurice is offline   Reply With Quote
Old 04-29-2013, 05:56 PM   #8
My Ride: Lexus
that front point is only applicable to the m3 or early e46s with the "bar" style reinforcement
Old 04-29-2013, 06:32 PM   #9
2003silver330i
Can you remove the plastic jack block and use a piece of 2x4 wood in that area instead of the plastic block?
Old 04-29-2013, 07:41 PM   #10
yurekk
My Ride: 2003 325i
So where do you jack the front up for late year e46, besides stock rubber jack pads?
yurekk is offline   Reply With Quote
Old 04-30-2013, 04:54 AM   #11
AquaRelliux
It can be removed prolly have to brake it tough, Dont you guys think it can be bent back and function properly? Here is a picture, not the best one but you can see that lifting block is closer to the sideskirt than it should be.
Old 04-30-2013, 05:31 AM   #12
paraklas
My Ride: ESS TS2 320ci
The reinforcement plate has a place for the jack in case you want to lift from the front.
Old 04-30-2013, 08:59 AM   #13
AquaRelliux
So what do you think about the picture can it be repaired? It is hard to see that any bending has occured tbh
Old 04-30-2013, 10:39 AM   #14
My Ride: Lexus
No it doesn't. Not on the non-M. Only the ///M plate is structured for that and braces directly against the subframe.
http://forum.e46fanatics.com/showthread.php?t=950785
Old 04-30-2013, 12:21 PM   #15
Kubica
My Ride: 2003 325xi
Incorrect. All xi's have a front middle jack point too.
Old 04-30-2013, 12:22 PM   #16
My Ride: Lexus
I don't acknowledge XIs
Old 04-30-2013, 12:33 PM   #17
AquaRelliux
So do u think i can repair the bent floor myself??
Old 04-30-2013, 12:36 PM   #18
My Ride: Lexus
I can't see the picture but probably. Maybe you can bang it back down with a hammer from the inside of the car
Old 04-30-2013, 12:47 PM   #19
AquaRelliux
I dont think there is a way to get to it from the inside of the car?
