Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 05-07-2013, 12:10 AM   #18801
WDE46
My Ride: '13 128i, '04 330Ci
Originally Posted by BBBoy323i View Post
Attempted to install my new FSU...really fast shipping from Pelican, but damn I'm stuck figuring how the hell to get that duct out of the way. Otherwise it was smooth, but back breaking work.
It seems like you're going to break it, but you just gotta push/pull a little harder to be honest. It's not easy to get out. Try various angles and whatnot.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 05-07-2013, 12:33 AM   #18802
BBBoy323i
My Ride: 01' 325ci
Okay I'll try haha, I give up...cut myself
BBBoy323i is offline   Reply With Quote
Old 05-07-2013, 08:14 AM   #18803
Adionik
My Ride: Bavarian Panzer
Originally Posted by RKiepper View Post
When people say leave 8 hours to do it, they mean it. I took stuff off for an hour and didn't get close. Can't even see or get to it without tearing apart half the engine. Ridiculous.
I can pull the rear suspension or put in an engine in half the time it takes to do this damn CCV.
In an hour I had everything removed. I haven't started putting everything back together though.
I always get nervous because I hear insane predictions like 8 hours for CCV, 2 hours for steering coupler and it didn't take me anywhere near that amount
Originally Posted by Brinkley View Post
I tried to start my car without my undertray today. It exploded in a ball of fire. I put the tray back in, hoping that will fix the issue.
Adionik is offline   Reply With Quote
Old 05-07-2013, 09:12 AM   #18804
David McMahon
My Ride: '99 E38 740iL
Well in the last week I've lost then found my keys, almost lost my Tax disc (luckily it feel between the glass and dash) and yesterday my Peugeot 206 managed to get a flat Tyre, so now I have no cars on the road as waiting to get my pulley for my E46
David McMahon is offline   Reply With Quote
Old 05-07-2013, 09:41 AM   #18805
college46
My Ride: Alpine White
clay bar whole car and mineral spirits to get the tar off the sideskirts. Removed oxidation from headlights.
Going to Bimmerfest West
01 325i ZPP 5 speed, 101,xxx
college46 is offline   Reply With Quote
Old 05-07-2013, 10:10 AM   #18806
WDE46
It kind of depends on if the car is being stubborn. The steering coupler should only take an hour really, but some people's get stuck. I couldn't get my new one back on until I unlocked the steering wheel and let it slip one spline over. I imagine the CCV will have several of these unforeseen trouble areas.
Old 05-07-2013, 10:23 AM   #18807
college46
Steering coupler takes an hour, its more of a tight working space its like two torx bolts, iirc 8mm works and a good wack at the coupler.
Old 05-07-2013, 10:32 AM   #18808
tcphoto
My Ride: E92 335 MT Coupe
It is a little scary to pull on the center console but the duct will slide out and give you access to the module.
tcphoto is offline   Reply With Quote
Old 05-07-2013, 10:40 AM   #18809
blkonblk05
My Ride: 2005 325i
Re: * What did you do to/for your E46 today? *
Wasn't today was last weekend. Installed new trans. Installed new lca front and adjustable rear. Installed coilivers sittin a bit too low but have not adjusted yet. Filled shifter rod with lead. This week new kicks. Adjust suspension. Unfortunatly i lost my freakin phone while fixing a buddys jeep. So All photos are lost.
Oh forgot also replaced radiator.expansion tank and starter. Not bad for a weekend!!
Sent from my DROIDX using BimmerApp mobile app
blkonblk05 is offline   Reply With Quote
Old 05-07-2013, 10:58 AM   #18810
WDE46
8mm ratcheting box wrench was my secret for that job. The bolts were easy. Getting the thing off and on was hard. I used a huge flat head screwdriver and a rubber mallet to get the old one off.
Old 05-07-2013, 11:21 AM   #18811
college46
Filling your shifter rod with lead was the dumbest thing you could do. Have fun damaging your synchros when you slam your gears in. Not to mention your hurting your shift input bushing which has severly degraded by this point. Just buy a z4 or e60 m5 shift rod if you already spent all that money. This is how you should fix your shift linkage. http://forum.e46fanatics.com/showthread.php?t=900208
Old 05-07-2013, 11:34 AM   #18812
blkonblk05
My Ride: 2005 325i
Maybe so. The reason for the trans replacement was the jackwagon that owned the car before me trashed the 2nd gear syncros. Actually it slides into gear pretty well so i dont have to "slam" my gears. It was a free mod from another site figured what the hell. Trans comes out easy enough if i dont like it.
Old 05-07-2013, 11:39 AM   #18813
SManganella
My Ride: 04' 325ci
Cabin air filter came in this morning & took a nice little ride to school and back
Follow me on Instagram: sam_manganella
SManganella is offline   Reply With Quote
Old 05-07-2013, 11:52 AM   #18814
Adionik
Manuvering the steering shaft was the worst part.
I know the CSB is going to give me problems. I'm also dumbfounded at how my Guibo has arrows pointing in BOTH directions.
Old 05-07-2013, 11:57 AM   #18815
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
You know that UUC and RE both make weighted selector rods right? On E36s it was common to wrap the selector rod with lead tape as I remember.
Tim
tim330i is offline   Reply With Quote
Old 05-07-2013, 12:03 PM   #18816
blkonblk05
My Ride: 2005 325i
Tim
My point. I got the site info from an e36 m owner. I just modified the free mod by using wheel weights and a torch melted it down and poured it in. Maybe a bad idea with the known weak syncros maybe not.
Old 05-07-2013, 01:25 PM   #18817
college46
Increasing the weight of the selector rod leads to easier shifting from the user, this often leads to the driver using to much weight leading to damaging synchros.
Tim
I do know UUC and RE both make weighted selector rods, along with there being a variety of options for weighted shift knobs. I still believe that most on this forum will damage their synchros because they are careless shifting.
I also don't see why you wouldn't replace the shift input bushing first. That is the number one contributor to poor shifter feel.
Old 05-07-2013, 03:19 PM   #18818
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
All this talk of people playing with their rods is making me excited.
Schlag96 is offline   Reply With Quote
Old 05-07-2013, 03:33 PM   #18819
My Ride: Lexus
The number one feeling to poor shifter feel in our cars, at least for the S5D320z ZF unit, are the infamous shifter detent pins. I would say if you have this unit, don't bother with shifter upgrades unless this job is completed
Old 05-07-2013, 03:37 PM   #18820
Eisenheim
My Ride: 2002 PY E46 M3
Replaced the Differential Pinion Seal, flushed diff and replaced 5 power steering hoses as well as flush the power steering system.
Steering feels like new, and the diff is a lot more happy
Eisenheim is offline   Reply With Quote
Rate This Thread
