Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 05-07-2013, 03:41 PM   #18821
My Ride: 2016 Lexus
Originally Posted by Eisenheim View Post
Replaced the Differential Pinion Seal, flushed diff and replaced 5 power steering hoses as well as flush the power steering system.
Steering feels like new, and the diff is a lot more happy
great work. thats the way to do it.
Old 05-07-2013, 04:03 PM   #18822
MikeyManBMW
My Ride: 2002 BMW 325xiT
Replaced the (probably original) fuel pump, which finally gave up the ghost at 141K mi. Replaced the fuel filter and tank seal too.
The $$ I saved doing some earlier DIYs from this site paid for the labor on this one after having AAA tow the car into the shop.
Mike || 2002 325xi Touring, Steptronic, 156K mi
Grey Green Metallic on Beige, Piano Black Trim, Armrest Delete
Factory Options: Power Heated Leather, Driver Memory, Harman Kardon
Outfitted: OEM Roof Rack | Dension Gateway Lite Bluetooth
Third owner since Mar 2013 || First BMW
MikeyManBMW is offline   Reply With Quote
Old 05-07-2013, 05:48 PM   #18823
Zchild
My Ride: 2000 BMW 3XXi ZSP
Finally got the last CEL turned off... Fault code D8 the Leak Detection Pump reed switch not open issue. It turned out to be the vacuum line from the Fuel breather valve to the throttle body was disconnected. Also found that one of the grommets under the VCG was missing which contributed to the vacuum leak as well. I believe this is the first time in 5 months I don't have a CEL illuminated in my E46. Thank you Benchmark Motors, you fixed the only issue that stumped me for the last couple of months.
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 05-07-2013, 05:56 PM   #18824
tcphoto
My Ride: E92 335 MT Coupe
I cannot believe how challenging it was replacing the vacuum hose on the Vacuum Control Switch. There was a little residue from the old hose and it was impossible to get a firm hold on it let alone see it. I ended up removing the plate that holds the cabin air filter, got frustrated, took a short break and then it slide on within minutes. What a day, I hope to never reach that point again. After clearing the codes, I took it for a drive and watched it roll past 120K and I fell in love with her again.
tcphoto is online now   Reply With Quote
Old 05-07-2013, 07:35 PM   #18825
lszlszx
My Ride: 1.8T, XC70
I installed these roof racks I bought on Craigslist.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 05-07-2013, 07:58 PM   #18826
college46
My Ride: Alpine White
Nice going skiing anytime soon? They look good and I hope you took them off after they fit properly. This is the best time to buy roof racks imo. Good purchase.
Going to Bimmerfest West
01 325i ZPP 5 speed, 101,xxx
college46 is offline   Reply With Quote
Old 05-07-2013, 09:42 PM   #18827
CK325
My Ride: 323Ci, 325xi
Well nothing today yet, but gonna need to change valve cover gaskets in the morning before going to Syracuse to pick up a CSL trunk and hopefully installing that after!
CK325 is offline   Reply With Quote
Old 05-07-2013, 09:45 PM   #18828
effay
My Ride: 323Ci
Originally Posted by E46Moonlight View Post
Nice! Post pics!
It's from fleabay so it's nothing crazy and it's not the traditional tri stitch that I've seen.
effay is offline   Reply With Quote
Old 05-07-2013, 09:57 PM   #18829
THECLEANERBEAMER
My Ride: 2002 325i
The carbon fiber cloth looks horrible why not just vinyl wrap it?
Instagram:thecleanerbeamer
THECLEANERBEAMER is offline   Reply With Quote
Old 05-07-2013, 10:09 PM   #18830
hizhinezz
My Ride: 01 330i
* What did you do to/for your E46 today? *
Yikes.
hizhinezz is offline   Reply With Quote
Old 05-07-2013, 10:17 PM   #18831
lszlszx
My Ride: 1.8T, XC70
Thanks! No skiing, but sometimes I have to carry stuff that doesn't fit
inside the car.
Old 05-07-2013, 10:28 PM   #18832
Hollywood516
My Ride: 02 330i
were you getting P0171 P0174 lean codes because of the missing grommet? I ask this because I am getting these codes after replacing my VANOS seals last weekend. I had a grommet that was still on when I re-installed the cover so when i tightened it, I'm almost sure I cracked the cover (causing a vac leak, and the lean codes)
Hollywood516 is offline   Reply With Quote
Old 05-07-2013, 10:30 PM   #18833
Hollywood516
My Ride: 02 330i
That trim needs help
Old 05-07-2013, 10:30 PM   #18834
Hollywood516
My Ride: 02 330i
Are you going to see AdamE46 ??
Old 05-07-2013, 10:43 PM   #18835
briangl92
My Ride: VQ37VHR
Wrapped the elephant trunk
Attachment 504483
Sent from my iPhone
briangl92 is offline   Reply With Quote
Old 05-07-2013, 10:45 PM   #18836
tock172
My Ride: '12 135i DCT
Attachment 504483
Sent from my iPhone
Nice job! I would attempt this as well but I know it would come out looking like ****.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT
Old 05-07-2013, 10:52 PM   #18837
briangl92
My Ride: VQ37VHR
It's tricky because the tape doesn't want to hold on to the taper of the grommet portion so I wrapped the last bit into the grommet so that it's held and can't slide under tension.
I didn't have the heart or ambition to cut all the wires, put a new elephant trunk on, and resolder the wires, like Dmax.
Sent from my iPhone
Old 05-08-2013, 12:58 AM   #18838
CK325
Indeed, sir.
Old 05-08-2013, 01:03 AM   #18839
jbaikw
My Ride: 2000 328i
Finally installed new smoked led tails, switched to smoked sides from clear, oil change, air filter change to an AFe Pro Dry, and cabin air filter. Now only need to do a wash, too bad it might rain this week again.
jbaikw is offline   Reply With Quote
Old 05-08-2013, 01:46 AM   #18840
trj
My Ride: 325Ci
Rear wheel bearing done
Hopefully the noise will not be there when I drive tomorrow.
Rate This Thread
