Sponsored by BimmerWorld
Old 05-06-2013, 11:37 AM   #1
LittleBear
My Ride: 2001 330i
Pentosin LV brake fluid?
Hello BMW Experts!
Does anyone know the lowdown on this Pentosin Low Viscosity brake fluid. It says it was developed for the X5 & is good for all BMWs.
http://www.autohausaz.com/search/pro...@Brake%20Fluid
TIA! Murf
"The Indian smiles, he thinks that the cowboy is his friend. The cowboy smiles, he is glad the Indian is fooled. Now he can exploit him"
LittleBear is offline   Reply With Quote
Old 05-06-2013, 03:11 PM   #2
My Ride: Lexus
Not sure. but why would you want to?
Old 05-06-2013, 05:37 PM   #3
LittleBear
My Ride: 2001 330i
It's made specially for BMW. Sort of like you are only supposed to use BMW coolant/antifreeze because that has a different viscosity.
Murf
Old 05-07-2013, 05:36 AM   #4
Dirtsquirt
My Ride: Wagon (its no e30)
The coolant has a different additives package (and blue color), that is why it is special. That brake fluid is something else entirely.
Stick with DOT3/4
Dirtsquirt is offline   Reply With Quote
Old 05-07-2013, 03:15 PM   #5
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
I would recommend ATE Super Racing Blue. It has a higher boiling point than the Pentosin.
Pentosin Super DOT 4: Dry Boiling Point: 260 deg. C (500 deg. F). Wet Boiling Point: 165 deg. C (329 deg. F)
ATE Super Racing Blue: Dry Boiling Point: 280 deg. C (536 deg. F). Wet Boiling Point: 198 deg. C (388 deg. F).
Drew@Swift Motorworks is offline   Reply With Quote
Old 05-07-2013, 04:14 PM   #6
LittleBear
My Ride: 2001 330i
Thanks for the replies, folks. Out of curiosity, wat up wit da 'Low Viscosity' labeling?
Murf
Old 05-07-2013, 07:15 PM   #7
Past Site Sponsor
...well its a lower viscosity than the standard DOT 4
Old 05-08-2013, 08:19 AM   #8
LittleBear
My Ride: 2001 330i
...and this is good or bad?
Murf
Old 05-08-2013, 10:00 AM   #9
CirrusSR22
My Ride: E36 318ti, E46 323it
The Pentosin website makes a couple references to the cold weather properties of the LV. MY guess is its akin to a 0w-xx motor oil. Just a better formula for cold weather. Maybe the X5 that this was designed for has a newer/different ABS/DSC system that the engineers thought a LV brake fluid would be beneficial in extreme cold??
I use Valvoline "Synthetic" DOT 3/4. Made in America, available everywhere, works in everything, and much cheaper that Pentosin or ATE.
CirrusSR22 is offline   Reply With Quote
