Old 07-02-2012, 12:00 PM   #41
mekaneck
My Ride: 2003 325xi
I just repaired mine with the help of this thread, it was pretty simple. My left brake light wasn't working (but only when my headlights or parking lights were off) and both left and right blinkers weren't working. I've got everything working now, and took me about an hour. Here's a simple DIY:
1. Remove the black box from your tail lights. It's connected by two connectors; one to the tail lights and one to the resistor.
2. Get the circuit board out of the black box. It is basically a container that they set the circuit board into and then fill up with epoxy, so it isn't easily removable. I had to use a hammer and wood chisel to basically destroy mine to get inside. It may not look like it, but I tried to do as little damage as possible so that I could maybe tape the box back together when I was done.
3. Take a soldering iron and heat up and re-solder the pins. I re-soldered any that didn't look perfect; there were a couple that had a dark ring around the connection. I did NOT solder any together, I just fixed the connections that were already there. I think I re-soldered about three connections on each tail light. The small pins looked fine, I just focused on the large solder joints. I didn't use any new solder, and I didn't suck any old stuff up with de-soldering braid. I just heated and re-melted what was there already.
4. Plug the circuit board back in and test everything. Once you get it all working, wrap up the board in electrical tape. I put some of the remains of the black plastic box back on for protection, and then taped it all up. Who knows how long this fix will last, but it's working perfectly right now. Fortunately it will be easy to re-solder if I have to do it again.
2003 325xi Black
mekaneck is offline   Reply With Quote
Old 07-02-2012, 12:31 PM   #42
trj
My Ride: 325Ci
Good work.
I don't think its the components that are substandard, its the solder joints that come undone.
As long as you keep those joints refreshed, you should be fine.
Mine is still working after this fix, almost after 5-6 months I guess.
Old 07-24-2012, 01:11 PM   #43
bparka12
My Ride: 330ci
hey just another confirmation as "mekaneck" did above ... i re-soldered all the soldered points and now it works like brand new! No more getting pulled over for me! Just go to radioshack if you don't have an soldering iron they are $9.00 get the 15amp one so you don't cook the board... i also beefed up the soldering points a little with radioshack's 62/36/3 .022" diameter solder for added security; it seems as though the little Asian kid in China didn't use enough solder the first time thanks guys for all your help on here! i spent a few hours yesterday trying to get a hold of someone to buy a new resistor/cap box... no need now
VMR VB3 - ZHP FCA - UUC ROTORS/P1 FW/SWAYBARBARIAN/SSK EVO3 W/DSSR - DINAN CARBON FIBER CAI - SHARKED
bparka12 is offline   Reply With Quote
Old 07-24-2012, 01:16 PM   #44
trj
My Ride: 325Ci
Glad this thread is helping many people.
Old 10-03-2012, 08:15 AM   #45
Oz Striker
My Ride: '00 330Ci, '07 350Z
excellent that you guys figured out a possible solution, I've followed the DIY and simply heated up the larger solder points, some of them looked like they had black hairline fracture lines in them. Havent had a chance to put it back in yet but will report back on whether successful or not.
The trickiest part is prying open the box. I used soldering pen with a knife attachment, a screw driver and a pick tool. Also dont bother trying to cut into the epoxy resin with the solder, its rock solid.
I thought i would take some more pics for ppl thinking of attempting this, to make it clearer how to open the box. Hope this also helps:
My YouTube Channel incl Muffler delete vids: http://www.youtube.com/user/OzStryke...view_as=public
My blog on E46 DIYs & Mods http://lifewithabmw.blogspot.com/
Oz Striker is offline   Reply With Quote
Old 10-03-2012, 11:22 AM   #46
VonGeiss
My Ride: 2002 m3
So happy I found this thread, my passenger side blinker is on the fritz. I'm going to take apart that box, and check out and re-solder anything that looks bad. Subscribed.
2002 Carbon Black ///M3 - current
2002 Stahlgrau ///M3 - RIP
2001 325i - sold
Instagram: @VONGEISS
VonGeiss is offline   Reply With Quote
Old 10-05-2012, 09:45 PM   #47
shahbaz99
My Ride: Clean 330ci
I just used this thread to fix my passenger tail that would work here and there. So the culprit was the stupid little black box as usual. A few tips that I would like to share.
-You dont need to completely ruin the box when trying to open it. I just took a utility knife and cut down one corner of it, then stretched it open and pulled out the board. It even snapped back into place when i was done and there was no need for tape. I put it on anyway though LOL.
-have it plugged in while the box is open and touch around until your tail lamp turns on. easiest way to diagnose
-My area that needed re soldering was those two pins that the guy earlier in the thread soldered together. I didnt solder them together just because that doesn't make sense to me. I just blobbed a bit of solder on each to secure the connection, making sure that they dont touch each other.
VIOLA! My tail lights are perfect again! Thank you fanatics, you just saved me $200. This site has been SOOOO good to me over the years of owning this car.
shahbaz99 is offline   Reply With Quote
Old 11-06-2012, 09:16 PM   #48
dn84
My Ride: 02 e46 ///M
Smile
I found out my taillight was acting up and it's a good thing I searched! Picked up a soldering iron, checked for the faulty points on the board and soldered it.
Lets see how far this takes me but for now, thanks for this thread.
dn84 is offline   Reply With Quote
Old 11-08-2012, 04:28 PM   #49
SRAM3
My Ride: 02 IMOLA M3
Wow, got the same problem, glad I came across this thread, I've been pinching the box together for it too work for weeks.
SRAM3 is offline   Reply With Quote
Old 02-24-2013, 04:06 PM   #50
mekaneck
My Ride: 2003 325xi
I just had to fix my lights again, my original fix didn't last even 6 months. This time instead of using a soldering iron to heat up the solder joints, I just used a heat gun aimed at the board, and "refreshed" all the solder connections at once. This was way faster (took about a minute) and has fixed everything that was not working. I'll see how long the fix lasts this time, but so far I think this is a much better method than reheating with a soldering iron.
2003 325xi Black
Old 05-08-2013, 05:48 PM   #51
VonGeiss
My Ride: 2002 m3
I finally got around to trying this, I just wanted to say again how happy I am I found this thread, it worked, at least so far! I had an intermittent ride side blinker, and I found that the solder joints in the top right, there's three in a row, seem to control the blinker. While I had the blinker going and it wasn't working well, I was able to touch it with the metal part of my key and it would start working, then stop when I came off it. I re-soldered them, and added just a tinyyyyy little bit to them and wa la!
Top three in red in this pic (i borrowed another pic in this thread to highlight the spots I'm talking about)
2001 325i - sold
Old 07-08-2013, 12:51 PM   #52
ecwx215
My Ride: None
Sorry, had to bring this thread back from the dead.
I tried the solder method and it works fine for about a day or 2 and then quickly dies out after again.
I spoke with a rep at Khoatly in June and they said they will produce a revised resistor and should be released in Mid/Late June . I've followed up with them, and they never gotten back to me.
Are there any other sponsors that is selling the resistors / capacitor boxes?
I'm tired of having my taillight go out and everyone honking at me to let me know it's out...
ecwx215 is offline   Reply With Quote
Old 07-08-2013, 04:29 PM   #53
trj
My Ride: 325Ci
Remove the old solder with de-soldering braid and apply fresh solder.
If you want a new box, send a PM to bryan@jleviSW. He can hook you up with a new box. I almost ordered the resistor box from him, but my fix is still working, its been more than a year and no problems.
Old 07-08-2013, 05:18 PM   #54
ecwx215
My Ride: None
Just gave them a call. Unfortunately they no longer carry them since the vendor doesn't produce them anymore. I'll try the resoldering method one more time.
Old 01-09-2014, 05:54 AM   #55
Tonyukuk77
My Ride: 3.20Ci
Sorry to ressurection the post but i have nearly same problem too. i have 2001 e46 coupe. i am little new that bmw and forums so be nice
My turn signals not working sometimes(?), i always testing before drive but first my signals ok, when i try to stop buy something from store or etc, i turn the four-way flashers, my right signal is not working, not always but this is really annoying problem. i have also problem that is my left signal little less brighter that right one.
i have discovered that black box (srry i dont know whats that "attachment") that inside LED tail lights , when i randomly touch my metal key problem solved sometimes. So i need that black box's circuit so i can make my own. Could you post here, componnents and circuit boards?
i am gonna try to re-solder the pins this weekend, i will let you know the result.
Thanks for reading.
Tonyukuk77 is offline   Reply With Quote
Old 01-09-2014, 06:57 AM   #56
ti317
My Ride: 02 330ci coupe 5 spd
If the soldering doesn't work, mine did for a few months and then quit, Khoalty has a replacement resistor pack that is plug and play for Eagle Eyes and works flawlessly.
The only difference between death and taxes is that death doesn't get any worse every time Congress meets. - Will Rogers
ti317 is offline   Reply With Quote
Old 01-13-2014, 01:47 AM   #57
Tonyukuk77
My Ride: 3.20Ci
i re-soltered pins (especially three pins that top right ) at weekend and problem gone. i hope it never repeat again. Thanks for thread.
Old 04-20-2014, 11:03 PM   #58
erbeman
My Ride: 99 323I
I troubleshot a brake light that was out and found it to be this little black box. I was able to pry the board out of the black box. I resoldered almost all of the joints and it started working. I was able to slide the board right back into the black box. Thank everyone for their posts.
erbeman is offline   Reply With Quote
Old 06-06-2014, 05:34 PM   #59
ahull
My Ride: 2003 330i
+1 Great thread.
My LED rear blinker failed (after 6 or 7 years of no problems) and I traced the problem to this box, then found this thread after some searching. I carefully hack-sawed the back off the box and soldered two of the those three joints together and it worked again. Sawing - don't saw all the way through the plastic, just most of the way through, along the edges like the burning pic above. Takes a couple of minutes and is cleaner than burning or chipping as seen in some of the posts above. Then you can pop the last little bit by prying with a screwdriver.
I think my LEDs are DEPOs but the black box is the same.
03 330i ZSP - Mods -> Supercharger, ZHP Rims, LED Tails, clear corners/markers w/ LEDs, Angel Eyes, ultra-white halogens and fogs, aux input.
ahull is offline   Reply With Quote
Old 07-27-2014, 01:54 PM   #60
xtmp
My Ride: E46
Smile
Just registered to tell you thanks! You guys make my day!
It all started when I bought my E46, with these f***ing chinese eagle eyes. I have humbled the fact that its are constantly flickering, but its began to fail. All as you write here.
I opened black box, soldered contacts, but it did not really help, and then I cut these thick wires and soldered it on top of the contacts on the board. Now it works.
Thanks again, guys!
Name:	2014-07-27 19.43.56.jpg
PS. Sorry for translate by google
xtmp is offline   Reply With Quote
