E46 Convertible
Old 05-09-2013, 06:01 AM   #1
Offshore24
My Ride: 2002 BMW 330Ci
Driver window not moving for door closure
'02 330Ci Vert. My driver window is no longer opening slightly when the door is open and then moving into the fully closed position when the door is closed. So, the window is hitting against the pillar and I have to push the window in/down as I close the door to get it to seal properly. Other than that the window operates properly. If I put the windows up after I put the convertible roof up it seals properly so the door and window are in the correct positions.
It's the automatic slight drop of the window and then full up sequence that has stopped. I tried a search but it's kind of a complicated thing to look for. Any experieces with this problem?
Offshore24 is offline   Reply With Quote
Old 05-09-2013, 07:39 AM   #2
fmzip
My Ride: '08 328xi / '01 530i
- Put the key in position 1 so you have power to the windows.
- After the window is all the way down, push and hold down the window switch for 5 seconds. This re-sets the memory, telling the motor which position the window is in
- Roll window back up, and release switch.
- Open door, step out of car and you should see the downward movement of the window again......
fmzip is offline   Reply With Quote
Old 05-09-2013, 07:45 AM   #3
Offshore24
Thanks Fran, I will try it this afternoon. One question, all this is done with the ignition inposition 1? Including getting out of the car?
Old 05-09-2013, 08:19 AM   #4
fmzip
You can turn the key off and then get out of the car
Old 05-09-2013, 08:25 AM   #5
Offshore24
Looking forward to it. Thanks.
Old 05-09-2013, 04:48 PM   #6
ibooste90
My Ride: e46 cabriolet
i'm going to have to try this on my passenger side. i notice it goes down but not enough to clear the rubber trim. thanks!
ibooste90 is offline   Reply With Quote
Old 05-09-2013, 05:59 PM   #7
Offshore24
It worked thanks fmzip
Old 05-09-2013, 07:44 PM   #8
fmzip
Old 05-09-2013, 08:26 PM   #9
FLarrazabal
My Ride: 325Ci
I have the same problem, the issue is with the door lock mechanism not telling the system that the door is open. The door open light and overhead light also quit at the same time. When the temp is hot it works intermittently, but when cold not at all. The built in switch in the lock mechanism is what is faulty.
FLarrazabal is offline   Reply With Quote
Old 06-14-2014, 09:38 AM   #10
workman482
My Ride: 01 M3 vert
Not just to revive a useful thread, but this worked for me as well on my 01 M3 vert
workman482 is offline   Reply With Quote
Old 06-16-2014, 10:56 AM   #11
The Thomas J
My Ride: 2002 325Cic
Sometimes old thread's r the best threads
The Thomas J is offline   Reply With Quote
