Meyle HD CAB vs Lemforder - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 05-10-2013, 09:54 AM   #1
Keaton1
My Ride: 2001 330 CIC
For several months now, have been trying to resolve a periodic vibration that seemed to be coming from the front (felt like primarily front left side) of my 2001 330 CIC at all speed from 30 mph or so and up.
I had redone most of my front suspension and some of the rear, installing the following new items: Meyle HD front control arms with new ball joints and bushings, struts, strut mounts, shocks, shock mounts, bump stops, sway bar links, and front and rear reinforcement plates. My tie rod ball joints were fine, so didn't install the new tie rods I'd purchased, hub bearings seem good, are smooth with no noise or wiggle, steering coupler looked in good shape when friend turned back & forth. Went through two alignments and two tire rebalances, one each at dealer, and BMW specific independent shop.
Would still get a periodic vibration, or minor shudder. After looking through several posts here and at Bimmerfest, kept seeing several comments that folks also had vibrations with Meyle HD CAB's that were resolved when they switched back to OE BMW or Lemforder bushings (which are said to be OEM). So I finally replaced the CABs with a Lemforder set, and got one final alignment.
Voila! A smooth ride, with no vibration or shudder. So just my 2 cents worth and experience. While I like Meyle products in general, I would recommend folks go with OE or Lemforder CAB's over the Meyle HD ones.
Keaton1 is offline   Reply With Quote
Old 05-10-2013, 09:56 AM   #2
My Ride: Lexus
I have had Meyle HD cabs for years now. No vibrations. Perhaps the Lemforder's compliance is masking another problem
Old 05-10-2013, 10:09 AM   #3
bmw8427
Banned User
My Ride: 330ci
I've heard of people that had trouble with the meyle strut mounts before but never the cab's. I just replaced my car's original control arms and bushings with zhp arms and the meyle hd bushings and that's a GOOD combination.
bmw8427 is offline   Reply With Quote
Old 05-10-2013, 10:16 AM   #4
Jesse M
My Ride: 05' ZHP
Where did you buy the zhp specific arms?
Jesse M is offline   Reply With Quote
Old 05-10-2013, 10:49 AM   #5
MixFlame
My Ride: 2004 330i
i also had issues with my meyle fcabs so far. think it might be a ride height issue in my case though
Sponsored by: Meguiars | Rotiform | AUTOcouture Motoring | Broadway Static
Instagram: @mystic330i
MixFlame is offline   Reply With Quote
Old 05-10-2013, 10:56 AM   #6
Keaton1
I kinda wondered about that, too, but was running out of things to try, what with all the other new items I'd already done. Only thing I really still wanted to do is replace the RTAB's but since the car is finally smooth, may hold off on that for a little while.
Anyway, thanks for your help. Alot of the stuff I've replaced was based off your's and other forum member's recommendations in previous posts.
Old 05-10-2013, 11:43 AM   #7
bmw8427
Banned User
My Ride: 330ci
I got them as part of a kit from fcpeuro.com
Old 05-10-2013, 12:23 PM   #8
My Ride: Lexus
a good tip is to never assume that all balancing jobs are created equal. try a different place. some machines and techs suck and aren't calibrated.
any time
