Sponsored by BAVSOUND
Old 04-22-2004, 08:01 PM   #1
niL
is on da floor
niL's Avatar
My Ride: 2001 330i
Send a message via AIM to niL
Good place to tap power for a tv tuner and two headrest monitors?
I got all my wires ran for the tv and tuner, i just need power now! wheres a good place to tap into power from should i get a relay or something and tap it into a switched wire or something? i'm not too familiar with rigging up a relay although they look easy
2001 330i rebuilt from the salvage yard
From start to finish...
niL is offline   Reply With Quote
Old 04-23-2004, 12:59 PM   #2
TreMontana
My Ride: 318ti->323ci->325ci
i need this info as well
also what brand monitors do you have and how is the quality? I decided on a 2 sunvisor/ 2 headrest setup but dont really trust the quality on the ebay ones....let me know- thanks-
TreMontana is offline   Reply With Quote
Old 04-23-2004, 01:19 PM   #3
ca1242
My Ride: 2003 330i
What other aftermarket equipment do you have? Do you have amplifiers, head unit, etc?
You could have a relay connected to the head unit turn power on and off, that way anytime the head unit is on, everything else is. As far as main power, you can go to the head unit harness, if current draw is not too much.
Another place you can tap is the phone harness under the center console (it has power and switched power), for low current devices.
I have information on how to wire up relays on my website: http://home.comcast.net/~customcarstereo/
Old 04-24-2004, 10:43 PM   #4
niL
is on da floor
niL's Avatar
My Ride: 2001 330i
going with myron and davis! quality is good. www.streeteffectz.com for more info, drop them a line
Old 04-24-2004, 10:56 PM   #5
niL
is on da floor
niL's Avatar
My Ride: 2001 330i
no amps or aftermarket head yet, was going to wire up the tv's seperate until i can get a head and some amps and subs. thanks for the site very helpfull, i'm going to wire a relay up to the phone harness under the center console
Old 04-25-2004, 08:37 AM   #6
ca1242
My Ride: 2003 330i
If you are going to the phone harness, you don't need a relay, just get switched power (I belive the wire is violet/w some other color - check with a meter) and also ground (brwon wire, but there are two and one of them is NOT a ground, so check). If you want to be able to turn it on and of with a switch, just switch the power wire.
Old 04-26-2004, 11:38 AM   #7
niL
is on da floor
niL's Avatar
My Ride: 2001 330i
Thanks, i will check it with a meter. I was going to go with a relay only because i thought the devices i wanted to power were too much for the phone harness but i'll give it a shot then thanks alot
Old 04-26-2004, 03:05 PM   #8
ca1242
My Ride: 2003 330i
You can check and see what size is the fuse size in the fuse bix for the phone circuit, but I doubt that a couple screens and a tuner will draw that much current.
