Sponsored by BimmerWorld
Old 05-06-2013, 10:20 AM   #81
WDE46
My Ride: '13 128i, '04 330Ci
Originally Posted by Mango View Post
Yeah but you're probably also comparing your new poly bushings to your old worn out rtabs if what you are saying is your experience. you already said you don't remember how your M3 rubber rtabs performed when new.just sayin!
Well, I kind of agree with LittleBear on the wheel movement thing. See, a busted RTAB is just an extreme case of compliance where the trailing arm can move freely. The rubber is less than that and the poly is even less than the rubber. It would make sense to me that the poly could actually help with tramlining. Does that make sense to you? I don't know if it's clear what I'm thinking.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 05-12-2013, 10:49 AM   #82
Razmataz77
My Ride: 2002 325i
I have researched some of the grease used on the poly bushings such as Marine grease, white lighting or copper lube... Any thoughts which one is the best or most effective to eliminate the squeaks.
I'm installing my POLY RTABS today and would appreciate the quick feedback.
I did not see much info with the search button....Thanks for the help in advance....
Razmataz77 is offline   Reply With Quote
Old 12-05-2013, 11:13 PM   #83
rkneeshaw
My Ride: 330i ZHP
Someone help me understand this:
The limiters install on each side of the RTAB, limiting movement. Don't they prevent that side-to-side movement that Mango is saying is key to proper suspension articulation as much if not more than poly RTABs?
So how is OEM+limiters all that different from poly RTABs when it comes to this "binding issue"?
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 02-13-2015, 02:47 AM   #84
rkneeshaw
My Ride: 330i ZHP
I guess that last post was a stumper.
I've since removed my RTAB limiters and installed PowerFlex poly bushes. Even with the limiters, my stock bushes wore out and were causing some squirm in the back of the car. So I replaced with the setup with the powerflex RTABs.
Overall I really notice zero ill effects. I will comment that with just the right kind of bump in the road it will feel slightly harsher than it used to, but 99% of the time the only thing different from the setup with limiters is a nice solid rear end.
2003 BMW 330i ZHP
