Sponsored by BimmerWorld
Old 05-11-2013, 06:54 AM   #1
certify
My Ride: 328i 2000
Eibach wheel clearance question.
I just installed bilstein b8 with eibach combo which i got from my friend's 330Ci and installed them in my 328i. My question is the front is 1 finger clearance but the rear is about 2 finger clearance. It this normal?
certify is offline   Reply With Quote
Old 05-12-2013, 06:51 AM   #2
certify
My Ride: 328i 2000
Was wondering if the part number are the same for 330Ci and 328i.
Can anybody please share some light?
Old 05-12-2013, 09:48 AM   #3
JohnBlaze
My Ride: Black Sunshine
probably no worries, if you want to bring the back down you could try removing the spring pads, or replacing those with a thinner version
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 05-12-2013, 12:05 PM   #4
certify
My Ride: 328i 2000
What is the factory original size spring pads for 328i? 10mm?
Old 05-26-2013, 05:38 AM   #5
certify
My Ride: 328i 2000
Last week just replaced the worn spring pads. But I'm already on 5mm.
Now my rear is still sitting high. Will pos pictures later
Old 06-02-2013, 11:51 AM   #6
hughfr4nc15
My Ride: BMW 318i E46
Just got a new set of Eibach installed and I got the same issue, rear is higher than the front... Will it settle? :|
hughfr4nc15 is offline   Reply With Quote
Old 06-02-2013, 11:59 AM   #7
Leezy321
My Ride: 2001 bmw 325i
Which Eibach springs? I know the pro kit always sits higher in the rear and do so on every car that I've seen with them. Search any car forum about Eibach pro kits and everyone has the same issues.
Leezy321 is offline   Reply With Quote
Old 06-02-2013, 12:03 PM   #8
hughfr4nc15
Yep, Pro-Kit :|
Old 06-02-2013, 12:13 PM   #9
Leezy321
Originally Posted by hughfr4nc15 View Post
Yep, Pro-Kit :|
That's just how they are man... And it seems hit or miss bcuz some ppl seem to have an even drop. But in my experience, no matter the make/model of the car, Eibach Pro Kit sits higher in the rear.
Old 06-03-2013, 01:50 PM   #10
hughfr4nc15
Today i installed 18'' rims and they look awesome, it seems much more leveled.
I'm happy with the result anyway!
Old 06-08-2013, 06:37 AM   #11
certify
My Ride: 328i 2000
You mean with bigger wheels its less obvious?
Old 06-08-2013, 07:31 AM   #12
hughfr4nc15
Yep, with I think that with my older 195/65 r15 the front was a bit lower because the rubber yielded much more than with 225/40 r18. I am sure of it because in the 2 days I had my car lowered with my older rims it always scraped in my garage ramp, with the 18'' that does not happen (although it is close ) and when I measured the wheels outsid of the car it was the exact same distance from the floor to the center hub.
You can see the current look in my car pics.
