Old 05-11-2013, 12:08 PM   #1
trivium630
My Ride: 2003 325i
sqeaking noise need help
I'm getting sqeaking noise while idling, just replace idle pulley and both tensioner pulleys , noise still there! wtf .. what else could it be?
trivium630 is offline   Reply With Quote
Old 05-11-2013, 04:40 PM   #2
lszlszx
My Ride: 1.8T, XC70
I am assuming you replaced the belts as well. It could be one of the accessory drives, like water pump. Take the belts off once again and spin all the pulleys, you might be able to tell that way.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 05-11-2013, 07:05 PM   #3
trivium630
My Ride: 2003 325i
yeah new belts, I'll try that, driving me nutz
Old 05-19-2013, 10:19 AM   #4
dokjones
My Ride: 1998 323ia e46
I have the same issue, mine sounds like there are seals hanging out in the engine compartment. I have a video I'll try to share where I moved around the engine compartment to give a bit of a Doppler on where the noise is coming from. Previous owner said the mechanics at the dealership told him it was the heat shield but that makes no sense. Pretty sure it is coming from the belt/pulleys. I plan to replace the belt soon so I will update afterwards.
dokjones is offline   Reply With Quote
Old 05-19-2013, 11:10 AM   #5
dokjones
The video as promised: http://sdrv.ms/12mA2pK (sorry if I move the camera too quickly, the sound goes away from time to time)
Old 05-19-2013, 11:58 AM   #6
trivium630
My Ride: 2003 325i
mine is more of a whine or whistle , goes away when you give it some gas, guessing maybe alternator ,power steering pump or water pump,
Old 05-19-2013, 12:21 PM   #7
dokjones
Mine goes away when I rev over 1500 RPM in drive (automatic) or when I put the car in neutral... other times it goes away when I idle but give it gas while staying under 1500 RPM. Most of the time it will squeak a couple times after I turn the car off
Old 05-22-2013, 12:10 PM   #8
trivium630
My Ride: 2003 325i
thinking it might be my power steering pump, im gonna change this weekend and give update
