Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 94 votes, 4.98 average.
Old 05-18-2013, 08:05 AM   #2161
buddyn2007
My Ride: 2001 330ci Coupe
I have a 2001 330Ci e46. I installed the Eonon D5113. After the install the right side view mirror stopped working. A day later, the airconditioner stopped cooling and my signal flasher in the instrument panel stopped working. I brought my car to the service center and they told me that the radio was causing the problem. They returned the OEM radio and all went back to normal.
Need your help to find out what went wrong with my install. The antenna on my car is powered and has two connections. 1 for the power and the other for the signal. We connected the power but didn't connect the antenna correctly to the d5113 when we did the install. Could this have something to do with the problem?
buddyn2007 is offline   Reply With Quote
Old 05-18-2013, 08:05 AM   #2162
buddyn2007
Old 05-18-2013, 09:07 PM   #2163
The Thomas J
My Ride: 2002 325Cic
Dude, I told u YESTERDAY ur canbus adapter is bad. Disconnect it & see if everything goes back to normal. Did you do that yet??
The Thomas J is online now   Reply With Quote
Old 05-18-2013, 11:30 PM   #2164
buddyn2007
Ok, I think I'm beginning to figure it out. I did not connect the canbus adapter when I did the installation (this is the red coloured module that connects to the white plug right?). My 330ci does not have any steering wheel controls so I thought it didn't require this module. COuld this have caused the problem?
Old 05-19-2013, 10:42 PM   #2165
The Thomas J
Yes the white plug goes in to the canbus. Plug it in & see what happens.
Old 05-22-2013, 05:05 AM   #2166
jchuillier
My Ride: 330CD
Hello all,
Has anyone a solution for the preferences being not saved in Igo ? It's really annoying to have to redo the sequence each time...
Also Waze won't run it tells me I have to unmount my SD card....installation is perfect but it won"'t run, trapster runs like a charm....
jchuillier is offline   Reply With Quote
Old 05-22-2013, 05:05 AM   #2167
jchuillier
My Ride: 330CD
Pls delete, double posting
Old 05-29-2013, 11:11 PM   #2168
PainBreak
My Ride: 2004 325i
Originally Posted by jchuillier View Post
Hello all,
iGO is junk. I've been really happy with TomTom. I will say though, that once I was rooted, iGO had no problems saving the configuration to the SD card.
Is your car a Stu Stu Stammering Stan at 2800 RPMS? FLASH THE DME! http://forum.e46fanatics.com/showthread.php?t=966614
Enco B046 Android 4.04 Root/FAQ/Help: http://forum.e46fanatics.com/showthread.php?t=967737
PainBreak is offline   Reply With Quote
Old 05-30-2013, 02:15 AM   #2169
jchuillier
My Ride: 330CD
When I launch it Igo tells me that it's not possible to create a logfile of some sort and then it runs normally....each time the same.
What are the chmod parameters needed on igo's card ? I tried to change them to 777 using es file explorer but I got kicked out...
Thanks for the help
Old 05-30-2013, 07:37 AM   #2170
CTRob
My Ride: Alpine white e39
Pain break any joy figuring out the random boot sequence?
CTRob is offline   Reply With Quote
Old 05-30-2013, 12:08 PM   #2171
rmilleta
My Ride: 2005 325 IC
How can I get a copy of TomTom and would it work with the win version?
rmilleta is offline   Reply With Quote
Old 06-01-2013, 05:08 PM   #2172
jeffesaurusrex
My Ride: 2001 330Ci
http://www.ebay.com/itm/D5113U-7-In-...item5d3f90846f
Is that this same unit?
To me the button backlights look more red than the OEM... does it match?
jeffesaurusrex is offline   Reply With Quote
Old 06-01-2013, 05:26 PM   #2173
jchuillier
My Ride: 330CD
Re: Enco B046 - Dynavin Clone
It's the same. But is the software the same ?
Sent from my GT-N7105 using BimmerApp mobile app
Old 06-01-2013, 05:29 PM   #2174
jeffesaurusrex
My Ride: 2001 330Ci
It says WinCE 6.0, so I guess not. There are android versions too but they are approaching the price of a Dynavin.
How do the maps work? On my android phone it uses 4G/data connection to load the maps. I am guessing the maps are all stored on an SD card somehow? Does that work out of the box on the android version?
Old 06-01-2013, 06:08 PM   #2175
jchuillier
My Ride: 330CD
It works out of the box in Android but on my unit you must set the parameters each time....
Old 06-16-2013, 05:03 AM   #2176
dldbe46
My Ride: E46 318I
Hi guys, i'm having trouble plugin up the radio on my headunit
the cable i got with the headuint look like this
and the cable I've got from the car wiring harness look like this
how do i plug up the radio in my car?
dldbe46 is offline   Reply With Quote
Old 06-16-2013, 05:27 PM   #2177
CTRob
Hi folks any joy figuring out the random boot sequence?
Old 06-17-2013, 02:42 AM   #2178
jchuillier
My Ride: 330CD
Attachment 511298
Attachment 511297
Well, welcome to the lovely world of szenco
You need to make your own cable using a "fakra" male connector at one end that will plus in the existing car antenna and a 90 "din/iso" car antenna plus that you will plus in the szenco unit.
You can't use the provided cable because it won't fit in the car because of the air vent which is touching the back of the szenco unit....
Or if you're lazy you can play with this....
http://www.ebay.com/itm/Antena-cable...item4d03bc0214
Old 06-19-2013, 07:50 AM   #2179
dzieju
My Ride: R75 MonitorBoard BMW
Hi i buy this radio like in my movie
Can you tell me how can i change boot logo ?
dzieju is offline   Reply With Quote
Old 06-19-2013, 07:50 AM   #2180
dzieju
Rate This Thread
