e46 jizzabuild - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-29-2013, 08:18 PM   #41
02PRUV
My Ride: E46 M3 Turbo
Originally Posted by cryptonyte View Post
Can the Cable throttle pedal from the 2000 323i work in the 2003 330i drive by wire..........I need a cable pedal?
Sure does. That's what I used in the M3. It bolts in and clips in the floor the same way. There is a rubber bung in the firewall you push out and clip the cable bracket clip straight in and the throttle end is nice and easy to pull apart, cut down and put back together with a new end on it. Works a treat
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 04-29-2013, 08:21 PM   #42
cryptonyte
My Ride: 2002 e46
Thanks bro....planning on getting tuned this weekend and it would suck to have a malfunctioning pedal.
cryptonyte is offline   Reply With Quote
Old 05-10-2013, 07:24 PM   #43
cryptonyte
My Ride: 2002 e46
coming along.....I ordered the suspension today.
Old 06-07-2013, 02:11 PM   #44
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 06-07-2013, 09:04 PM   #45
Sedan Hussein
My Ride: e46
vids ASAP. Great work
Sedan Hussein is offline   Reply With Quote
Old 06-08-2013, 12:26 AM   #46
MalibuMafiaV
My Ride: E60 M5 & 335i ST
YES VIDEOS!!! PLEASE! this is absolutely great!
TheMalibuMafia.com
Instagram
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i - ST 6266
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
MalibuMafiaV is offline   Reply With Quote
Old 06-08-2013, 12:50 AM   #47
02black330ci
My Ride: spaceship
^^^ What they said!
02black330ci is offline   Reply With Quote
Old 04-10-2014, 07:23 PM   #48
avez97
My Ride: 2000 323ci
What are you wanting to get working? Keep the factory ECU in the car, speedo runs off the abs so it will still work, use the BMW water temp sender in the 1j so your water temp gauge works, use the BMW oil pressure switch so you have a working oil pressure light, use the BMW ecu alternator light wire so your alternator light works, use the 1j ECU tachometer output to go into a Dakota digital tachometer box and the output of that into the tachometer input on the BMW ECU.
Things like oil level, water level etc you can just short out to clear those lights. And things like check engine, eml etc you can get the ecu programmed to turn these off.
All of this should work in theory. Im doing it all at the moment with an LS. I'm even going to measure the resistance of the oil temp gauge and get a temp sensor than is the same resistance so I still have the oil temp gauge as well.
Great Project and Thanks for Sharing. Im looking to do the same swap with my 323ci. Where did you get your ECU programmed to turn off your "Check Engine" lights?
avez97 is offline   Reply With Quote
