Old 05-26-2013, 10:51 PM   #1
InDiGlOM3
My Ride: HPF M3 stg 2.5
Idle issue resolved, MAYBE
I have yet to go on a good test drive, but idle cold and even with me trying to piss it off it stayed rock solid, zero drop.
Ended up having two broke pins in factory DME (stayed in female side)
pics below of my ghetto fix but permanet.
I could easily get to one pin so i removed an unused on and placed in hole did a lil wrap and soldered. the other pin I couldnt get to so went to the back of the board used a wire and solder with some heat shrink for my shielding.
ID:	507735   Click image for larger version
ID:	507736   Click image for larger version
Old 05-26-2013, 10:55 PM   #2
Commanderwiggin
My Ride: 900rwhp Turbo M3
Mad props Jesse...lots of determination figuring that one out.
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 05-26-2013, 11:14 PM   #3
InDiGlOM3
Thank you Thank you, last thing is this damn knock, check out video I posted of it in my mysterious knocking thread.
Old 05-27-2013, 02:16 PM   #4
InDiGlOM3
Did a good test drive. Idle is fixed!!
Sent from my EVO using Bimmer App
Old 05-27-2013, 02:59 PM   #5
Providence
My Ride: HPF Stage 3 m3
Send a message via MSN to Providence
Good to hear that it is sorted out buddy
Providence is offline   Reply With Quote
Old 05-28-2013, 05:52 PM   #6
andynb
My Ride: e46 m3
Yeah you must have been digging into this for a while to find that...
andynb is offline   Reply With Quote
Old 05-28-2013, 09:45 PM   #7
InDiGlOM3
I fix cars daily. From Shitty Chevy trucks to high boosting cars of all types. I did complete vanos rebuilds on two m3's this weekend and mine. My noise didn't go away, theirs did. So I was bitching at my wife how I can fix everyone else's car in a day or less, troubleshooting all sorts of random stuff that nobody should be able to figure out but I cant fix my own damn car. Then i went out later that night and decided to disconnect all my harnesses and bam saw a bunch of corrosion on one plug and looked closer to seewo missing pins, look in plug side and saw them in it. Thing drives like its brand new with that fix and vanos rebuilt.
And no I don't do this kind of work for a living. I manage a diesel engine rebuild shop
Old 06-02-2013, 09:05 AM   #8
Cipri
My Ride: E46 M3 2002
Re: Idle issue resolved, MAYBE
I have exactly the same simptoms.
Can you please specify exactly which pins where broken?
I wonder why they breake? Could be from the AEM?
Cipri is offline   Reply With Quote
Old 06-02-2013, 11:30 AM   #9
InDiGlOM3
It was where. A factory connector plugged into the Dme. For some reason they were corroded so weakened them. It you unplug them all you should see if anything is broken. But just a loose pin in the jumper will cause sake problems so most likely you have a loose connection somewhere it seems that's always the problem with these symptom, loose or broken pin etc.
Old 06-11-2013, 10:44 AM   #10
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
Nice find... i can relate totally to hard to find issues... Keep up the good work... U have been helpful to me and I appreciate that...
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
