///M3 Forum
Old 05-21-2012, 12:31 PM   #41
golfesq
My Ride: m3
how's the hub holding up?
golfesq is offline   Reply With Quote
Old 05-21-2012, 07:52 PM   #42
turbotoy2791
My Ride: 04 m3
Not too good shadow's broke the tabs off shortly after the 15000 mile mark. The good thing is both tabs stayed in the pump they can not physical get out.
We are changing to stronger 4340 steel increasing tab size and increasing the radius at the bottom of the tab.
turbotoy2791 is offline   Reply With Quote
Old 05-21-2012, 09:26 PM   #43
new//M3fan
My Ride: 77' 924 87' E30
Damn, what the hell could possibly be shocking the VANOS tabs so much. No wonder BMW did away with the high pressure VANOS system.
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 05-21-2012, 09:47 PM   #44
turbotoy2791
My Ride: 04 m3
The cam springs springing the cam forward.
Old 05-24-2012, 01:17 PM   #45
new//M3fan
You mean the valve springs?
Old 05-25-2012, 10:14 AM   #46
roadtrip1098
My Ride: 06 STi
subscribed....
roadtrip1098 is offline   Reply With Quote
Old 05-27-2012, 09:11 AM   #47
Brian_67
My Ride: 2005 M3
Interesting stuff! I like the fact that this is looking to be a realistic option with turbotoy's continuing development.
Brian_67 is offline   Reply With Quote
Old 06-06-2012, 09:45 PM   #48
turbotoy2791
My Ride: 04 m3
Yea that is what I mean
Old 06-11-2012, 10:35 AM   #49
new//M3fan
Gotcha. And that causes the tabs to hit against the holes in the vanos pump. I wonder if using a Stronger spring washer inside the vanos hub would help keep the tabs from hitting the orifices too hard.
Old 06-11-2012, 08:06 PM   #50
Taper
My Ride: Espaņa
nice upgrade!
Taper is offline   Reply With Quote
Old 06-13-2012, 07:10 AM   #51
E46<3
My Ride: M
Please figure this out! I DD my 04' and see a full motor refurbish in the 130k range, this is on the checklist !
Do you listen to House?
Have a listen to my SoundCloud
https://soundcloud.com/bryanisaac
E46<3 is offline   Reply With Quote
Old 07-12-2012, 09:08 AM   #52
turbotoy2791
My Ride: 04 m3
Here is an update. We are changing the material to 300 maraging steel. We are also making the tab size larger to take some of the slop and adding a radius at the bottom of the tab. These new tab rings will be cut on CNC machines.
Old 06-11-2013, 10:31 PM   #53
redrider423
My Ride: 2005 BMW M3 6MT Vert
Vanos hub fixed
Any update on how the new design turned?
redrider423 is offline   Reply With Quote
Old 06-12-2013, 04:35 AM   #54
turbotoy2791
My Ride: 04 m3
Yes, the hub has been performing very well. One has 30,000+ miles on it. 33 of the 300c hubs are on the road.
Old 06-12-2013, 03:30 PM   #55
redrider423
Vanos hub fixed
Awesome. I would like to know if you are using the stock sized oil pump disk of a modified one with smaller holes. In the event that my pump disk is damaged and holes are unusable what options would I have using your hub? I'm in the process of gathering the cam bolts, rattle kit and seals to bulletproof my vanos system. This whole exhaust hub is my nemesis at the moment.
Old 06-12-2013, 09:32 PM   #56
turbotoy2791
My Ride: 04 m3
I designed my hub to be a direct replacement to the oem. The 300c hub has larger tabs to take up the slop in the pump disk holes. We can drill two more holes in your pump if your holes are scared up. You can also have a local machine shop drill the holes. The stock holes are .422 of an inch.
Old 06-12-2013, 09:39 PM   #57
Moosecakes
My Ride: 02' SMG M3
Can't wait to get my hub when I can afford it! for a great product!
Moosecakes is offline   Reply With Quote
Old 06-12-2013, 09:53 PM   #58
redrider423
Vanos hub fixed
Ok. I'm tearing it down in about 2 weeks. Pm me a price and info about ordering so I have a heads up. Thanks for investing the time in the solution.
Old 07-12-2013, 11:24 PM   #59
turbotoy2791
My Ride: 04 m3
300 maraging
Old 07-12-2013, 11:36 PM   #60
redrider423
Vanos hub fixed
Hey Scott did you get my message on M3F?
