Old 06-15-2013, 12:45 PM   #21
jfoj
My Ride: 330CiC, M5, X5, E93
You likely have lean codes, probably due to a vacuum leak as other mentioned above.
Read this - http://forum.e46fanatics.com/showthread.php?t=897616
Old 06-15-2013, 01:38 PM   #22
PosingOwl
My Ride: 2004 325xi
I do not understand how I am prepping for open heart surgery by just asking questions? I also didnt jump to any serious conclusions and dive into the car and start tearing everything up.
I do not believe that the weather was the culprit, and he probably did clear it. Thats why I usually go to O Reilly's instead of Autozone much (friendlier and helpful). Should have went there, but it was in the opposite way I was heading. Guess I will go buy one of the scanners. Is there still a way to find out problems from the scanner without and of the engine lights coming on?
Also, I was watch this guy with the scanner and I think I saw the P0174 code or something similar to it.
PosingOwl is offline   Reply With Quote
Old 06-15-2013, 02:13 PM   #23
dznuts007
My Ride: 2001 325i Sedan
Heheh I think the 80/20 rule even applies to aautozone workers? 80% of car owners think that clearing a code magically fixes all underlying problems. The other 20% actually try fixing the underlying problem.
If the SES light problem comes back, get yourself a scanner. I used to use a cheap one I got from Harbor Freight. Worked for to pull codes and clear them. I recently moved onto a USB OBD2 adapter to ise my laptop with BMW specific software to pull codes. Also have a bluetooth OBD2 adapter to use the Torque Pro application. Find em on eBay for cheap.
But either way having some type of scanner is gonna be recommended
Start doing some maintenance research and read jfoj's links and mango's links and think about starting on some DIY's to get your car in tip-top shape before problems occur
dznuts007 is offline   Reply With Quote
Old 06-15-2013, 03:19 PM   #24
jfoj
P0174 is the common code of these cars. Would be surprised to find an E46 without this code.
As for scan tools, you really need to have one of your own. It also needs to read and display Freeze Frame data.
Suggest you read this - http://forum.e46fanatics.com/showthread.php?t=967204
Would not recommend purchasing a scan tool from a local auto parts store, they are usually too expensive and lack a lot of the features you likely need, like live data, Freeze Frame, recording & graphing.
Old 06-15-2013, 04:33 PM   #25
jdstrickland
My Ride: '94 325iC & '00 323i
Having your own scan tool is a very good investment. Shop well, Grasshopper. This is one of those tools where you get more if you pay more, but there is a point of diminishing return. My scan tool was about $150-ish, including sales tax. I get freeze frame data and the unique (P1nnn) codes for every make of car out there. I do not have visibility to vehicle systems that are not engine management or emission control.
I did not mean to make you mad about prepping for surgery when you only need a bandaid, but there really is nothing you can do without pulling codes first. There is no point in buying stuff without knowing the code that your car has stored. There are literally one thousand things that can turn the light on. Some are duplicates and there are a few holes in the numbering scheme, but you get three digits all in a range of zero to nine.
