Australia
Old 06-05-2013, 08:50 PM   #1
trive2
My Ride: 1989 BMW 535i
Brake Fluid- Choices
Time to change the front pads and flush the brake fluid. My first choice of fluid, ATE Super Blue.
I love that the color makes it easy to know when it's fully flushed and it's considered a very good Super DOT4 which is exactly what I am looking for.
However, I've come to the conclusion that ATE Super Blue is too hard to get in Australia. No one will ship it internationally either.
I've also heard that certain products are considered better? There's a couple of Castrol products considered excellent.
Does anyone have any of their own experiences with certain fluids? (Super DOT4 specifically)
trive2 is offline   Reply With Quote
Old 06-05-2013, 11:42 PM   #2
DeclanM3
My Ride: 332Ci
I use RBF600, pretty happy with it but it might be a bit overkill if you're not tracking your car.
DeclanM3 is offline   Reply With Quote
Old 06-06-2013, 05:19 AM   #3
CortinaD
My Ride: lots
Go for the RBF600 as its readily available and cheap.
CortinaD is offline   Reply With Quote
Old 06-14-2013, 03:49 AM   #4
MSportBMW
My Ride: E46 325, EVO8 MR
I like RBF600 good pricing and widely available like Cortina said. I think Project Mu is good aswell. SRF too expensive I have used it once but can't justify the price but from memory its very high wet boiling point may lead to it lasting longer with less replacements so it may balance out...
MSportBMW is offline   Reply With Quote
Old 06-14-2013, 05:52 AM   #5
02PRUV
My Ride: E46 M3 Turbo
AP Racing 600 If you want good fluid for big brake work. Or AP Racing 5.1 or Castrol SRF for street and track days
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 06-14-2013, 08:03 AM   #6
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
DOT 5.1 which in specification is rated "safe" for a DOT 4 system.. I wouldn't do it.
After trying DOT 5.1 I found it held heat well, after draining it out... To swap out to brass guides/bushings it literally ate away my calliper seals!
Ended up rebuilding all the seals on the car.
E46 Coupe is offline   Reply With Quote
Old 06-14-2013, 12:11 PM   #7
Davconelectric
My Ride: 2 dog powered sled
Use the cheapest dot4 you can buy. For street use its all the same
Davconelectric is offline   Reply With Quote
Old 06-16-2013, 08:01 PM   #8
trive2
I'm thinking the RBF is the way to go! Cheers guys!
