Australia
Old 02-24-2013, 07:24 PM   #1
Tymatk
My Ride: X5
Who stock Dexron III ATF P/S fluid?
Guys
Which local automotive store stock BMW Dexron III ATF Power Steering fluid ........ or do you use a approved/same spec P/S fluid but a different brand?
Tymatk is offline   Reply With Quote
Old 02-24-2013, 08:18 PM   #2
Brissyjohn
My Ride: 2007 MX-5
I bought Castrol ATF Dex III from Repco.
Brissyjohn is offline   Reply With Quote
Old 02-24-2013, 09:01 PM   #3
Ballistic325
My Ride: slow and steady
^ Same at Super Cheap Auto.
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 02-25-2013, 12:56 AM   #4
fgin
My Ride: e46 facelift
If Castrol ATF Dex III good for transmission as well ?
fgin is offline   Reply With Quote
Old 02-25-2013, 03:57 AM   #5
Ballistic325
^ no. Good for power steering only.
Auto tranny needs OEM or OEM equivalent fluid and it's not Dex III.
I can help with
* RTABs
Old 02-25-2013, 07:15 AM   #6
spacemaster
My Ride: E46 328i
I use redline d4 for both.
spacemaster is offline   Reply With Quote
Old 02-27-2013, 06:19 PM   #7
Tymatk
My Ride: X5
I love Redline
Do they make Redline shock proof for BMW automatic gear box?
Old 02-27-2013, 09:21 PM   #8
spacemaster
My Ride: E46 328i
not sure what you mean, but my car is auto.
Old 02-27-2013, 11:36 PM   #9
Tymatk
My Ride: X5
Sorry, what i was meant to say is ZF gear box, auto, 5 speed.
Old 02-28-2013, 12:26 AM   #10
Ballistic325
If you have a look over in the general and DIY sections, there is info on the different gear boxes and compatible fluids. You can track down your gear box type and work out what's best for you.
I can help with
* RTABs
Old 02-28-2013, 12:29 AM   #11
Mf3st
My Ride: e46M3
I have one.. Full bottle
Mf3st is offline   Reply With Quote
Old 02-28-2013, 12:32 AM   #12
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
E46 Coupe is offline   Reply With Quote
Old 02-28-2013, 12:33 AM   #13
Mf3st
My Ride: e46M3
^^lol
Old 03-03-2013, 06:37 PM   #14
jojotikang
My Ride: 2003 e46
Hi guys..am just new in the forum.
Planning to do my tranny oil change.does anyone know where i can buy the filter kit zf 5hp19?
I've tried clickableauto no stock.hsy for wholesale only.help pls?
jojotikang is offline   Reply With Quote
Old 03-03-2013, 07:12 PM   #15
Davconelectric
My Ride: Mainly cars
Bmw Melbourne.
Davconelectric is offline   Reply With Quote
Old 03-04-2013, 11:31 AM   #16
jojotikang
My Ride: 2003 e46
Originally Posted by Davconelectric View Post
Bmw Melbourne.
expensive..$170.$45 @ clickableauto..
Old 06-16-2013, 08:38 PM   #17
Alpine
My Ride: 2002 E46 BMW 330Ci
Just confirming this would be the right fluid to use for my power steering (cap says "ATF fluid only"):
How much would I need to do a flush? Would this 1litre bottle cut it?
Alpine is offline   Reply With Quote
Old 06-17-2013, 12:38 AM   #18
Brissyjohn
My Ride: 2007 MX-5
Yep, that's it. I bought a 4 litre bottle and have just under 3 litres left after two complete drain/refills.
Old 06-17-2013, 01:23 AM   #19
Alpine
Thank you, sir. I think I will also go for the 4 litre bottle, and keep the rest for future flushes...
Old 06-17-2013, 01:59 AM   #20
trive2
My Ride: 1989 BMW 535i
I'm assuming you are going to use the correct fluid yah?
Try Imparts, or just buy from overseas.
trive2 is offline   Reply With Quote
