HELP!! How do I replace Factory HIDs with aftermarkets? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-18-2013, 03:41 PM   #1
CWMcGee67
My Ride: 05 330i zhp
Question HELP!! How do I replace Factory HIDs with aftermarkets?
I had just purchased an 05 330i M and I'm looking to replace the OEM HIDs with aftermarket headlights but it seems I can fit regular projectors on the factory HIDs... How would I go about changing the headlights to fit an aftermarket? Thanks to anyone who can help.
CWMcGee67 is offline   Reply With Quote
Old 06-18-2013, 03:45 PM   #2
My Ride: Lexus
why on earth would you do that? what lights are you planning to install
Old 06-18-2013, 04:01 PM   #3
SB_RavenE46
My Ride: 330CI ,06 R6, S1000
Send a message via Yahoo to SB_RavenE46
Dude just stick with the factory's or do a projection retrofit aftermarket headlights fit like crap unless u go with depo
M0ney = P0w3r "THEN" I = A G3nerat0r
SB_RavenE46 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-18-2013, 04:36 PM   #4
mach460
My Ride: 04 325 xi
Yep I did depo projection with angle eyes on my 04 and they fit and work perfect best mod I did ...
mach460 is offline   Reply With Quote
Old 06-18-2013, 04:42 PM   #5
Riverbmr3
My Ride: MB E350 & BMW 325i
P46 with canbus xenon and orion v2 from Umnitza, so happy with it.
Riverbmr3 is offline   Reply With Quote
Old 06-18-2013, 05:46 PM   #6
choxor
My Ride: JDM
This.
Old 06-18-2013, 07:33 PM   #7
jfoj
My Ride: 330CiC, M5, X5, E93
3rd on why would you want to replace the OE HID???
If there is an issue, better off working with the factory OE and sorting them out.
There have been issues with some of the projector lens, but why woud you want to replace the OE lights????
Old 06-18-2013, 10:43 PM   #8
CWMcGee67
My headlights are so messed up and I cant afford the OEM HIDs, is there any way to replace them without sacrificing quality?? I keep hearing that Depos are pretty good (on here too). Any other suggestions?
Old 06-18-2013, 10:51 PM   #9
Zell
Zell's Avatar
My Ride: so turbo wow
How are they messed up? You can probably repair them. You won't be able to get a good setup without spending good money, and headlights are not something to cheap out on because you could blind others or not see well. If you did use a new projector, I'd recommend Infinitu FX45 projectors. They're apparently legendary.
http://www.theretrofitsource.com/pro...roducts_id=122
Are your bowls burned?
Old 06-18-2013, 10:56 PM   #10
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
If by messed up you mean the lenses are beat to sh!t from rock chips, the covers can be replaced with genuine BMW for about $65 shipped IIRC.
/// MODS
/// Auto => 6-Spd Manual Conversion | Apex EC-7 | Koni/Ground Control Coilovers | Vorshlag Camber Plates | BMW Performance LCA | Mishimoto Intake Boots | GruppeM rep CAI | Shark Injector | 5000k Xenarc CBI 66240 HID | BMW European MTechII | BMW Performance Shifter | ACS Mirrors and Rear Spoiler ///
Old 06-18-2013, 11:00 PM   #11
jfoj
Explain "so messed up"????
First you need to know how they work before you can determine what the problem is.
Many of the problem are with the leveling system and can be repaired very cheaply and easily or the reflector bowls may be the plastic that the reflective surface degrades. This can be repaired as well.
Old 06-18-2013, 11:08 PM   #12
Solidjake
Radar Specialist
Solidjake's Avatar
My Ride: '13 328i Msport 6MT
He probably has ZKW lights.
OP either retrofit in better projectors or get a set of halogen headlights and put in Morimoto mini projectors.
Moved to the correct section
Old 06-18-2013, 11:14 PM   #13
CWMcGee67
One is, the other looks water damaged (Don't even ask) or something. I was originally just gonna install some Angel Eyes but these lights are too shot.
Old 06-19-2013, 04:15 AM   #14
dznuts007
My Ride: 2001 325i Sedan
Pics!
dznuts007 is offline   Reply With Quote
Old 06-19-2013, 05:54 AM   #15
jfoj
Sandy car?????
If so, headlights may be the least of your worries.
Old 06-19-2013, 12:36 PM   #16
umnitza
8774866489
umnitza's Avatar
My Ride: E39M5, Sequoia
All you would need to upgrade or update your lights is a set of FXR projectors and a set of covers.
Both reasonably inexpensive:
http://www.umnitza.com/e46-headlight...es-p-6112.html
And this:
http://www.umnitza.com/hid-projector...1197_1212.html
Give us a call and speak to Tim We have many projectors in stock.
Old 06-19-2013, 12:40 PM   #17
Solidjake
Radar Specialist
Solidjake's Avatar
Originally Posted by dznuts007 View Post
Pics!
+1 post some pics.
330, headlights, hid, projectors, replace
