Old 05-29-2013, 08:48 AM   #1
Tament
My Ride: 2001 330I
Vanos Seal Kit
Can someone tell me what comes in the Beisan vanos seal kit. looking at the picture, it seems for $60 you get 10 gaskets/O-rings in total:
Two seal rings from each piston groove, total of four rings for each piston (2 pistons, total 8 seal rings), and 2 piston cap O-rings.
Name:	Piston Cap O-Ring.jpg
It does not seem like the Vanos to engine gasket is included, please let me know if I am correct in this thinking. Some of you have done this repair before, let me know what you recieved with the kit, what additional parts you had to purchase.
On a side not, I just did my VCG approximately 1 month ago, can I reuse the VCG or do I need to get a new one. I just have a diesel like sound under the hood, and I am sure this repair has never been done.
Tament is offline   Reply With Quote
Old 05-29-2013, 08:56 AM   #2
cposk
My Ride: 08' E90 M3
http://www.beisansystems.com/procedu..._procedure.htm
Go to the section "Parts/Tools/Shop Supplies". Everything you need is listed.
cposk is offline   Reply With Quote
Old 05-29-2013, 09:18 AM   #3
kydspd
My Ride: 328i
Get a new VCG and do it again IMO... especially if you used a VicRiens gasket and not OEM or Goestke... It's only 20 bucks and could avoid you a lot of hassle.
Maybe look into getting the rattle kit also, even though it's a way tougher job than just the seals... You most likely will need it.
kydspd is offline   Reply With Quote
Old 05-29-2013, 09:43 AM   #4
paraklas
My Ride: ESS TS2 320ci
Attachment 508057
Attachment 508058
Attachment 508059
Vanos housing to block/head gasket is NOT include, however cheap from dealer. Cannot be reused.
You CAN reuse the valve cover gasket though
Here's the said vanos gasket (wrapped one in the pic below)
Old 05-29-2013, 10:43 AM   #5
Tament
My Ride: 2001 330I
Sweet, Should have read about the vanos before doing my VCG, but hell, you can only read so much at anyone time. Thanks for the info
Old 05-29-2013, 01:13 PM   #6
SC4R27
My Ride: 03 325i Sport Pckg
i just replaced the o rings and seals on my vanos pistons along with the VCG yesterday. What comes inside is 2 piston cap o rings, 4 piston groove teflon seals and 4 piston o ring seals.
SC4R27 is offline   Reply With Quote
Old 05-29-2013, 01:15 PM   #7
Tament
My Ride: 2001 330I
Did you order from Beisan, what was your total out the door for the kit, shipping and all?
Old 05-29-2013, 01:56 PM   #8
WDE46
My Ride: '13 128i, '04 330Ci
Yeah, you need that VANOS gasket. Buy it separately. Also, buy an X-acto knife. You will need it to remove the old O-rings. Do not try to pull them out with an O-ring pick. They need to be cut carefully.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
