Old 06-22-2013, 03:27 PM   #1
shadow 2
My Ride: 07 328i
Valve Job Cost
02 325xi needs oil rings and valve seals. What would be a typical cost for the parts and labor?
shadow 2 is offline   Reply With Quote
Old 06-22-2013, 04:41 PM   #2
lszlszx
My Ride: 1.8T, XC70
It depends on where you take it, but you can expect $4-5000 for an engine rebuild.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 06-22-2013, 06:40 PM   #3
shadow 2
My Ride: 07 328i
Don't need an engine rebuild, just valve work.
Old 06-22-2013, 08:43 PM   #4
wildirish317
My Ride: 2004 325Ci vert
Oil rings being valve stem seals? If you're talking piston oil rings, you're beyond the head and into the block, and into an engine rebuild.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 06-22-2013, 09:04 PM   #5
e46alfonso
My Ride: 330xi MT, mustang gt
use a heavier oil or swap a b30
e46alfonso is online now   Reply With Quote
Old 06-22-2013, 09:57 PM   #6
inlinesicks
My Ride: E46, Jeep, Subaru
You would be better off just buying a used engine.
inlinesicks is offline   Reply With Quote
Old 06-23-2013, 07:04 AM   #7
shadow 2
My Ride: 07 328i
B30? This the 3 liter motor? What heavier oil meets BMW LL-01 standards? Mobile 1 0-40 is too thin and I see no other "heavier" oil listed.
Old 06-23-2013, 07:09 AM   #8
shadow 2
My Ride: 07 328i
Thing is it runs fine with no noticeable lack of power. Guess I can keep putting oil in it every 800 miles but hate to do that since it will eventually screw up my cats.
Old 06-23-2013, 07:49 AM   #9
jfoj
My Ride: 330CiC, M5, X5, E93
So the real question is have you ever replaced your CCV and cleaned out your dipstick tube?
Crankcase vacuum is KEY to controlling oil consumption in these engines.
Before I would tear the engine apart, I would replace the CCV system, remove and clean out the dipstick tube and change the oil to Castrol 5W40 as shown in the picture.
Also what is the engine temperature operating point?
As for BMW LL-01 approval, I would not get to wrapped up on 100% only using oil that is LL-01 approved. This is really only an issue for warranty coverage and if you plan on running with the 15k mile oil change interval.
If you are currently using Mobil 1 0W40, just changing to the Castrol may significantly improve your situation.
Suggest you fully read the 3rd link below in my signature along with all the info on the CCV and mayo build up.
One other suggestion which will likely get a lot of other comments it to pour a can of SeaFoam in the crankcase 500 miles before you change your oil.
Name:	Castrol Edge Front.jpg
ID:	512589   Click image for larger version
Name:	Castrol Edge Back Close 2.jpg
Old 06-23-2013, 08:57 AM   #10
shadow 2
My Ride: 07 328i
CCV changed for PM 16 months ago. Checked again this week including the dip stick, zero issues. Have used BMW 30 weight oil since I bought car 7 years ago.
Old 06-23-2013, 09:00 AM   #11
jfoj
If you are using Mobil 1 oil, change to Castol and verify engine temp is correct.
Old 06-23-2013, 09:03 AM   #12
jfoj
Also might want to pull the valve cover and see how much sludge may be built up in top of cylinder head. If there is a lot of sludge build up, then likely the cylinder head oil return holes may be restricted or clogged.
Old 06-23-2013, 10:28 AM   #13
shadow 2
My Ride: 07 328i
No sludge, changed VCG last year. Burning oil, why unknown. Jfoj, appreciate your time and advice.
