Old 06-07-2013, 09:13 AM   #21
M3 2 NV
My Ride: 2001 M3
Originally Posted by supersickbimmer View Post
Maybe we can ship ours out together.
Sounds good to me
2001 M3 - Phoenix Yellow - 03/01 production
M3 2 NV is offline   Reply With Quote
Old 06-08-2013, 12:31 AM   #22
leletyM3
My Ride: 05 M3
Would surely love to unlock mine as well
05 BMW ///M3 SMG - Jet Black/Gray
HPF Stg2 Turbo 640rwhp, Eisenmann Race 83mmx4, Volk TE37 TA, Toyo T1R, Brembo BBK 380mm 6pots & 345, 6k HID, 6K HID Fogs, Depo Smoked Corners, Strassentech Front Lip, V-CSL Bootlid, V-CSL Diffuser
leletyM3 is offline   Reply With Quote
Old 06-08-2013, 03:15 AM   #23
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
HPF and unlocking the AEM
Originally Posted by Forcefed M3 View Post
I don't know, let me PM Chris K and ask. I will also reach out to AEM to see if they can help.
Pm sent
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 06-08-2013, 03:59 PM   #24
Saad @ Saad Racing
Past Site Sponsor
My Ride: S600
We can unlock the AEM.
Saad @ Saad Racing is offline   Reply With Quote
Old 06-08-2013, 04:11 PM   #25
being3
Modded ///Member
being3's Avatar
Thanks for stepping up to do this
Who should we contact in ur company as what kind of cost is involved?
Old 06-09-2013, 08:36 AM   #26
supersickbimmer
My Ride: 617rwhp M3
Does anyone have an idea how much people are charging for this?
supersickbimmer is offline   Reply With Quote
Old 06-10-2013, 12:25 AM   #27
Saad @ Saad Racing
Past Site Sponsor
My Ride: S600
Just send me an email at Saad@SaadRacing.com and I'll get you taken care of.
Old 06-17-2013, 11:44 PM   #28
John Reed
My Ride: AE86
Originally Posted by SPDu4ea View Post
Standard JRR service (reminds me a bit of the Seinfeld Soup Nazi -- treat customers with such indifference they come back begging for more)... I used to have decent luck getting him on AIM, but don't know if that is still the case (or what his handle is).
It is standard as I am only one guy and try to sift through 50+ emails a day, all while trying to get the actual work done that pays the bills in between. I haven't been charging anyone to unlock their ECUs so I just get them done as I can.
I am pretty sure I got everyone unlocked that has emailed me thus far. No need to send anything anywhere.
John Reed is offline   Reply With Quote
Old 06-18-2013, 02:37 AM   #29
leletyM3
My Ride: 05 M3
Will e-mail you! Thanks for the great help!
Old 06-19-2013, 03:08 AM   #30
being3
Modded ///Member
being3's Avatar
If anyone needs to know how to wire in the serial port on a Gen 1 harness I have figured it out. Just PM me.
Old 06-20-2013, 03:24 PM   #31
being3
Modded ///Member
being3's Avatar
AEMPro software connect sequence. AEMtuner does not work with r Aem v1
AEM download link
http://www.aemelectronics.com/catalo...-downloads-72/
Important to follow or u will not be able to connect.
1 Car off
2 ignition off
3 have USB to serial cable plugged into computer and Aem
3 load AEMPro software
4 in dialog box select serial and choose comport from drop down box
5 Then select from dialog box connect In AEMPro
6 when Aempro has no communication errors and is waiting to connect then turn on ignition without starting car. If u have errors turn off car and wait 15 seconds then shutdown AEMPro unplug USB serial cable and put it back in and repeat above sequcence.
7 AEMPro will then download the calibration file for ur Aem and AEMPro will have live data
8 Then u can start the car if u wish
9 if u want to download the log u have to have the car off and follow the same above sequence.
10 if the software hangs for any reason then u have to repeat the same sequence. Sometimes u have to unplug the USB to serial cable and restart the aempro software
11 any changes u make in AEMPro while connected directly updates the AEM
Note: I know this is a pain in the ass but believe me this works and when u get the hang of it it's not a problem. I have spent a long time figuring this out so I want to save u guys the frustration.
Old 06-23-2013, 09:04 AM   #32
dragosid
My Ride: HPF 2.5 M3
Thanks a lot for the step by step procedure beign3!
Now, I'm a bit puzzled as I took out my AEM v1 today and I don't seem to have a Serial output. Anybody else in the same situation?
Pulled the trigger! Built engine + 6766 Dual BB + Open Dump + 15/23 PSI - Holy F#@$ this build is insane!
HPF Stage 2.5 - 739rwhp & 581ft-lbs SAE
best 1/4 mile (ST2) 11.77'@123mph 1.9' R/T on Toyo R888 295/30/19
Porsche Cayenne Turbo S - stock
dragosid is offline   Reply With Quote
Old 06-23-2013, 09:15 AM   #33
being3
Modded ///Member
being3's Avatar
Ur AEM is a Generation 1 as it has two connectors verses Gen 2 which has 3 smaller ones. So urs will not have a serial port on the unit. Only Generation 2 has it. If u look on the harness on the AEM side u will see a 3 pin connector labeled "aux sensor" this is the serial port on Gen 1. U need to add the DB9 Female connector. If urs does not have that u can add the the wires to the connector to the AEM. Pm me and I can get u going with the wiring. I have been helping a few with getting setup.
Old 06-23-2013, 02:09 PM   #34
Cipri
My Ride: E46 M3 2002
Re: HPF and unlocking the AEM
Can some ex-HPF guy provide us with the version 1 pinout?
It is a pain to not be able to do custom modifications...
Sent from my GT-I9505 using BimmerApp mobile app
Cipri is offline   Reply With Quote
Old 06-24-2013, 01:11 AM   #35
bwonders
My Ride: 2003 M3Vert HPF stg2
Here are the pinouts that HPF provided for pre-programmed options. Hope this helps. If it would be useful I can PDF the entire 176 page install manual complete with color photos. Just let me know.
ID:	512722   Click image for larger version
ID:	512723   Click image for larger version
ID:	512724   Click image for larger version
ID:	512726   Click image for larger version
ID:	512727   Click image for larger version
ID:	512728   Click image for larger version
ID:	512730   Click image for larger version
ID:	512731   Click image for larger version
ID:	512732   Click image for larger version
ID:	512734   Click image for larger version
ID:	512735   Click image for larger version
bwonders is offline   Reply With Quote
Old 06-24-2013, 01:36 AM   #36
Cipri
That's exactly what I was looking for.
Can you please scan all pages and upload the PDF somewhere so we could download it?
Old 06-24-2013, 01:36 AM   #37
bwonders
Sure I'll see if I can get it done tomorrow.
Old 06-25-2013, 01:49 PM   #38
Cipri
Bwonders, did you manage to scan the pages?
Old 06-25-2013, 01:52 PM   #39
Commanderwiggin
My Ride: 900rwhp Turbo M3
The manual is just for installing the HPF kit...he scanned all the pinout pages already.
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 06-25-2013, 03:00 PM   #40
Cipri
How can we find out remaining pins?
