Engine & Performance
Old 08-27-2012, 02:37 AM   #21
bimmerguy055
My Ride: M3
Send a message via AIM to bimmerguy055
Originally Posted by e60fan View Post
what do you think about e60 with M54B25? can I fit this manifold and turbo? I don't know how much space will be enough, can you measure it? also did you run on stock engine with 10.5 compression with no problems?
it will just clear using manifold, turbo, and the extension. I believe the expansion tank is right where the turbo would go, that would have to be relocated. Other than that, if you have fab skills, you can make it work to your liking.
Where exactly would you like a measurement? Yep stock engine, I just got a slightly thicker head gasket to lower the compression, and raceware studs. In-short, you will be fine. the 60 trim turbo is a great match, saw full boost before 3000rpms.
Without Failure There is No Success
bimmerguy055 is offline   Reply With Quote
Old 08-27-2012, 05:48 AM   #22
e60fan
My Ride: 525i
I think it can't fit
this are my pics, I have here antifreeze and DSC
I need bottom mount turbo manifold - may be you know who does it?
what head gasket do you use and compression in result? how much is ignition degrees retard?
ID:	466502   Click image for larger version
ID:	466503   Click image for larger version
e60fan is offline   Reply With Quote
Old 08-27-2012, 02:39 PM   #23
bimmerguy055
My Ride: M3
thats a bummer, your DSC would probably be flush with the intake to the turbo as top-mount. SPA makes a good manifold for bottom mount, I'm actually using one.
Now u may think $530 bucks is steep when there are other much cheaper (under $200) manifolds on ebay, that look similar, but there are 3 things wrong with them ( I had one):
- the casting is mediocre inside where they connect to the t3 flange.
- the wastegate flange is poorly located facing the firewall, (leaving an inch to make a 90 degree bend with 1.5" wastegate pipe (just about impossible)
- and finally the cheap manifolds have the turbo sit lower, (so it will be a greater chance with drain issues, and if you have a 4" intake on turbo u may hit the cross member from being to low)
I had about 15 degrees of timing, but the whole timing sync was off so the whole time it was retarted, not sure about how much off, I have to make timing mark and timing light and get some references
For the headgasket I ran http://store.vacmotorsports.com/vac-...mls-p1072.aspx at .040" which only slightly lowered my compression, but if you really want see the limit of the stock block, I'd recommend getting a .140" thick HG, that will dramatically lower compression, in to the 9s
Old 08-27-2012, 03:03 PM   #24
e60fan
My Ride: 525i
thank you!
as I think limit of the stock block in M54B25 are connecting rods, may be pistons and crank, in M54B30 crank very good (the same as in S52), connecting rods capable up to ~400 hp, pistons don't know.
I think about stroking out to B30 with stock internals, add head gasket .098" or .140", use SPA turbo manifold for bottom mount of Garrett GTX3582R and cheap universal FMIC intercooler package with SAMCO silicone hoses.
Old 08-27-2012, 03:17 PM   #25
bimmerguy055
My Ride: M3
thank you!
your welcome. may I ask where you got the info that 400hp is the limit for connecting rods? I've seen videos of a stock block m50 motor (with .140" HG and arp head studs) brake little over 700hp before something give'd.
I'm going to push the limit myself my new turbo will kill my engine quickly since its good for 740hp I'll be building a m54b30 on the side, soon.
Good luck with your future build.
Old 08-27-2012, 03:22 PM   #26
e60fan
My Ride: 525i
connecting rods in M54B30 are from M52B28 and in M50 used another, guys with e30 turbo goes ~500 hp and something was broken that used from M54B30, piston or connecting rod, I don't remember exactly
do you use boost controller? stock dme with tune? and how did you connect BOV with TB or some another scheme?
thank you!
Old 08-28-2012, 01:01 AM   #27
bimmerguy055
My Ride: M3
thank you!
hum, well Im hoping for 400whp on the dyno, cross my fingers nothing gives.
I'm using a electronic boost controller. Its a stand alone EMS, Pro EFI. Hopefully the picture is self explanatory
ID:	466600   Click image for larger version
Old 08-28-2012, 03:26 AM   #28
e60fan
My Ride: 525i
if you want will be 400 whp (on M54B25, what boost?)
thanks I see! so you drilled TB and use wireline, what a pity no pics of TB modificated
also I suggest you start your own topic with build description and photos - it's great!
Old 09-02-2012, 12:07 PM   #29
Sknutson913
My Ride: 01 325i
^^ +1
Sknutson913 is offline   Reply With Quote
Old 09-02-2012, 05:14 PM   #30
Russian172
My Ride: e46 sedan e46 m3
I want a build thread of this
Russian172 is offline   Reply With Quote
Old 09-02-2012, 07:52 PM   #31
bimmerguy055
My Ride: M3
I'd be in the range of 10-14psi, with moderate timing and a 6266 turbo should get me there
I never mod'ed the TB, just have a 2.5" to 3" coupler over it, along with a 1" coupler to the ICV.
I have somewhat of a thread of my build here
Old 06-18-2013, 02:37 PM   #32
bimmerguy055
My Ride: M3
still for sale guys!
Old 06-18-2013, 09:20 PM   #33
Hollywood516
My Ride: 02 330i
How hard is it to set up the standalone?
Hollywood516 is offline   Reply With Quote
Old 06-19-2013, 06:59 PM   #34
bimmerguy055
My Ride: M3
As an easy install thats straight forward. since they make a harness to be plug N play. depending what version of the ECU kit you get its just a matter of tapping into your fuel line, manifold, exhaust with the included sensors and a base map. then U just need to tweak the tune.
Old 06-25-2013, 05:32 PM   #35
bimmerguy055
My Ride: M3
bump
Old 07-12-2013, 02:49 AM   #36
alcolite
My Ride: 98 RS
Still got this? PM me a bottom price for the whle kit!
alcolite is offline   Reply With Quote
Old 07-13-2013, 05:20 PM   #37
bimmerguy055
My Ride: M3
I only have the TCD exhaust manifold and custom made t4-t3 adapter (angled to properly fit next to valve cover)
At this point I'll entertain prices for my current turbo setup with EVERYTHING fabricated
Old 07-31-2013, 07:39 PM   #38
bimmerguy055
My Ride: M3
bump
Old 08-04-2013, 10:33 PM   #39
bimmerguy055
My Ride: M3
just looked up the TCD site, and now they stopped making the m5X manifolds! now this is rare! still have the manifold + adapter!
Old 02-26-2014, 11:16 AM   #40
JDUTHIE
My Ride: 2003 325xi
Still avail?
JDUTHIE is offline   Reply With Quote
