Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 1.00 average. Display Modes
Old 06-29-2013, 11:07 AM   #1
BeMyWhip
My Ride: 01 BMW 330ci
Cool Carbon Brakes from Bavauto review...
So friday I completed my I installation of my Cool Carbon Performance brake pads
for both the front and rear. I also replaced the brake fluid with new Ate high performance
DOT 4 which has a higher boiling point and was blue in color. The color makes it very easy to see when you bled the new fluid through.
As a bonus, I figured I respray my calipers since the color got old and dingy.
and... since the car was up in the air on four jack stands, I did an oil change as well.
The pads have a specific break in which is included. they were on sale for $205 instead of $240. You also get a free tee shirt. Bleeding the brakes was so easy. Just watch some youtube clips to get a visual on how its done.
Another major bonus for me, I got rid of that annoying rattle I had in the rear of my car. One brake pad had a broken clip, and the other had that metal skin on the rear pad total loose.
Conclusion: im happy! Didnt get to drive the car around alot after the break in due to rain, but I did do a few very hard stops and it does brake hard and straight!
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 06-29-2013, 11:32 AM   #2
kejobe
My Ride: 2003 325I
Keep updated when you get some miles on them please.
All Stock...
kejobe is offline   Reply With Quote
Old 06-29-2013, 05:08 PM   #3
Brinkley
My Ride: 99 328i, 07 z4 3.0
I've had these on my car before, They are pretty good from what I recall.
Brinkley is offline   Reply With Quote
Old 07-12-2013, 03:20 PM   #4
kejobe
My Ride: 2003 325I
Update? How have they been?
All Stock...
Old 08-12-2013, 10:51 AM   #5
cmlf1
My Ride: 2002 330ci
I have Cool Carbon on my 2002 330ci for about a year and a half and 15,000 miles. I had issues with buildup of material on the rotors and had to "clean" them up until a few months ago quite often with hard stops from 70-80 MPH and then the steering wheel shimmy under light braking (feels like warped rotors) would disappear for a while. I now have a moment delay when braking in the wet and am going to replace them with Hawk street pads or oem/Pagid pads. I have no experience with the Hawk pads, so any input would be appreciated. The delay in braking when wet is horrible and I am going to change them soon.
cmlf1 is offline   Reply With Quote
Old 08-12-2013, 01:54 PM   #6
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
I love my Hawks in a Full race compound pad, but; For the street I only run Performance Friction Z-Rated Pads. This really is the best street pad (For Hard Driving) I've had the pleasure of using.
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 04-03-2014, 02:12 PM   #7
BeMyWhip
So I now had my cool carbon for about 9 months, and the fronts are squealing.
9 months?! Really?
I did like the braking performance, but I think they wore out prematurely.
Won't buy them again.
Always Mod!!!
Old 04-05-2014, 06:18 PM   #8
Alex323Ci
My Ride: M3 & 323Ci (sold)
9 months?! Really?
"squealing" doesn't mean they are worn out. you have to visually inspect as it might be as simple as the ant-rattle clips, the pads needing some "brake disc quiet" on the backing, re-used old rotors thus following the old grooves & edges or even the calipers having paint on the runners so the pad "ears" shimmy.
then again you have one of those Automatic/slushboxes so depending on driving style you might have worn them out...
it's not determined by "time" but "use".
