Top Dead Center Question - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-08-2013, 07:12 PM   #1
JasonSmithed
My Ride: 00 323i
Hey guys in need of some help.
replacing head gasket... I am trying to get my motor to TDC on my m52tub25 and am stuck. I have the intake manifold off, spark plugs removed, banjo fitting removed, all drive belt off, and I am trying to rotate the motor clockwise to TDC but it seems to be stuck. Will not budge is there something I am missing. maybe I skipped a step.
JasonSmithed is offline   Reply With Quote
Old 07-22-2013, 01:14 PM   #2
sleepymkiii
My Ride: Toyota Supra mkiii
The m52, if its like all other bmw engines is an interference engine, which means that when the valves are open, if the piston tries to come up to TDC, it will hit the valves. This is more than likely the problem you're having. I've never been inside an m52, but all the other BMW motors have wrench flats on the cams to turn them manually. Try turning the cams a bit and then try to spin the crank over to TDC
sleepymkiii is offline   Reply With Quote
Old 07-22-2013, 01:19 PM   #3
willsbma
My Ride: 99 323i
Take it out of gear?
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 07-22-2013, 05:02 PM   #4
BobbyC
My Ride: 2000 328I
This man has a point. Make sure you follow his advice, also, please tell me that you did not remove the timing chain before putting the motor to TDC and now you're trying to turn it over.
BobbyC is offline   Reply With Quote
Old 07-22-2013, 06:35 PM   #5
willsbma
My Ride: 99 323i
If you did that^ Youll never time those cams right so just tow it to a shop that has experience timing dual vanos when you're at that stage.
Sent from my DROIDX using Bimmer App
Old 07-25-2013, 03:13 AM   #6
JasonSmithed
My Ride: 00 323i
Car wasn't in neutral. I have replaced the head gasket, set the timing right, and put the intake on. Now my oil separator is spewing oil all over the place when I crank the car so I will likely buy all the hoses and redo the manifold and oil separator hoses. Oil may even be coming out of the dipstick since its such a large amount.
Old 07-26-2013, 09:13 AM   #7
willsbma
My Ride: 99 323i
Sounds grossly overfilled
Old 07-26-2013, 12:05 PM   #8
JasonSmithed
My Ride: 00 323i
No it does it until its completely out of oil I think it is the oil separator or the dipstick o ring isn't set
Old 08-02-2013, 07:37 PM   #9
JasonSmithed
My Ride: 00 323i
It was the lower feed for the vanos
Old 08-03-2013, 02:30 PM   #10
willsbma
My Ride: 99 323i
I've don't that myself. Luckily I could get to it after the manifold was back on.
