Old 07-03-2013, 03:08 PM   #1
Jeckospole
My Ride: 2001 325i
Help needed with something simple
Hey everyone I am new here, and I have finally begun to modify my bmw, one of the first installs I have done was adding a dynavin d99 system. It has gone smooth for the most part until I put the car back together and couldn't get my locks to work and my trunk release to work, I also think it is responsible for my taillight indicator.
I realized there was a cable (red gray) with a brown ground cable that wasn't hooked up to anything. Sounds simple, but I literally have searched the web and have been looking at my install for hours and cannot figure out where it goes. It is taped to the same strand of cables as the cigarette lighter but it has no where to plug into. Any help would be appreciated I have been working on this for far too long and need to get moving. I have attached pictures so you can see what I am referring to. Thanks in advanced Click image for larger version
ID:	514417Click image for larger version
ID:	514418Click image for larger version
Jeckospole is offline   Reply With Quote
Old 07-03-2013, 09:13 PM   #2
TurnersInOz
My Ride: 2004 325i
Those go to your cigarette lighter if I remember correctly.
TurnersInOz is offline   Reply With Quote
Old 07-03-2013, 09:59 PM   #3
iRide113
My Ride: 2004 M3
Cigarette lighter.
iRide113 is offline   Reply With Quote
Old 07-04-2013, 07:11 AM   #4
Jeckospole
My Ride: 2001 325i
Thanks for the responses, I know that the white and metal plug into the cigarette lighter but the black 2 pin plug doesn't have a spot there...unless I missed something...can anyone confirm the black 2 pin plug?
Regards,
Julian
Old 07-05-2013, 06:52 AM   #5
Boboshanti
My Ride: e46 330i and 316i
Regards,
Julian
Look into your ashtray, there is a little bulb in there.. the 2 pin plug goes behind a socket behind that bulb.... its right next to the cigarette lighter... here are some pics to show you exactly where it goes... i have Dynavin d99 android installed and made some pics whiles installing... hopes it helps
ID:	514738   Click image for larger version
ID:	514739   Click image for larger version
ID:	514740   Click image for larger version
Boboshanti is offline   Reply With Quote
Old 07-05-2013, 09:17 PM   #6
Jeckospole
My Ride: 2001 325i
Wow this is strange I observed and looked I don't think my relocation part of my dash came with a spot for that cable unless I am missing something...I attached a picture of the back of the unit! Thanks for your help everyone. Click image for larger version
Old 07-06-2013, 06:38 AM   #7
Boboshanti
Well i guess it has been prewired for that.... and doesnt currently plug anywhere..
Old 07-06-2013, 09:36 AM   #8
Jeckospole
My Ride: 2001 325i
That's what I'm thinking, well any idea where I could reconnect the wires so that I am getting power? I imagine I could splice them with another power source...thanks for your help man
Old 07-06-2013, 10:37 AM   #9
Jeckospole
My Ride: 2001 325i
After further investigation, I don't think the cable matters much? I think it is for the cigarette lighter bulb and doesn't have much to do with the power locks which just started working again? Can anyone confirm this? My trunk release isn't working but the cables in the back are cut right now, working on a rear view camera install!
Old 07-07-2013, 06:54 AM   #10
Boboshanti
Yes it doesn't matter.. its for the cigarette lighter bulb.. and it does nothing more than to power just that bulb... and probably your car has been pre-wired for that.. so it will be a simple DIY ( plug and play ) if you should decide to equip it with that in future...
* Which of your trunk release?? the one in car (driver side) next to the hood release or the one on the trunk itself????
Old 07-07-2013, 09:08 AM   #11
Jeckospole
My Ride: 2001 325i
Boboshanti, it's the one in the back, I believe it's because the wiring is disconnected as I am having to wait so I can finish the reverse camera set up, I disconnected the left license plate light cable so I can splice the wires with together with the power for the camera. Hope I didn't screw that up. If you have any thoughts let me know. Thank you for your help!
Old 07-08-2013, 11:55 AM   #12
Boboshanti
well i never had issues with mine as i was installing my reverse camera.. but i will suggest you get done with the camera and fix all back and if that still dont work, you troubleshoot that alone..
Old 07-10-2013, 12:24 AM   #13
TracieGreathouse
Banned
My Ride: honda city
Send a message via ICQ to TracieGreathouse
I think you have struggled a lot with it please visit the showroom or any other private garage to fix it up. Or else you will do more harm to your system and car too.
TracieGreathouse is offline   Reply With Quote
Old 07-10-2013, 04:45 PM   #14
Boboshanti
Jeckspole... are you done with fixing??? still having difficulties?
