E46 Xi Forum
Old 05-30-2013, 09:43 PM   #21
Kgoncalves
My Ride: BMW 325xi
2003 BMW 325 xi complications.
Still haven't found out the problem I asked my friend an told her about my problem an she called me a retard lol. But I keep having the same problem. I'm thinking the starter.
Kgoncalves is offline   Reply With Quote
Old 07-13-2013, 11:28 AM   #22
Kgoncalves
My Ride: BMW 325xi
What would you recommend to use for a tune up? What ignition could do you use, an what spark plugs an why?
Old 07-13-2013, 09:48 PM   #23
jmo69
My Ride: 03 325xi 98 328is
IDK what to use for a tune up and the plugs to use are BKR6EQUP.
As far as the ignition switch not turning all the way to start on the second try, you have to go back to off before trying again. I think it's to keep you from engaging the starter if the car is already running.
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 07-13-2013, 10:23 PM   #24
SamDoe1
My Ride: 4cyl of fury
The steering wheel has a lock on it that engages when you turn the steering wheel with the car off. With the lock engaged you cannot start the car. Turn the steering wheel one way while turning the key to disengage the lock. If one way doesn't work then go the other way.
If your problem isn't that you can't turn the key all the way then you'll need to check your electrical system and starter.
Old 07-20-2013, 09:15 AM   #25
Kgoncalves
My Ride: BMW 325xi
Electrical system starter, k will do.
I also have another problem. Click image for larger version
ID:	517365Click image for larger version
ID:	517366Click image for larger version
Old 07-20-2013, 02:14 PM   #26
Kubica
My Ride: 2003 325xi
^was it already broken? Scan codes and see if there's a misfire in that cylinder.
If not its probably ok.
Old 07-20-2013, 06:01 PM   #27
Kgoncalves
My Ride: BMW 325xi
We have been problems of it misfiring most of the cylinders. So I'm going to try process of elimination. I've replaced the plugs, coil packs. An I'm probably going to try to replace that part... Do you have any idea what it's called?
Old 07-20-2013, 06:25 PM   #28
White_Knuckles
My Ride: 2003 325xi
The broken plastic section is not causing multiple cylinder misfiring. You may have a lean condition from a torn intake boot, a common problem that appears as an ignition issue. You may be best off having a pro diagnose your problems before continuing throwing random parts at her?
Start here for parts and description hunting. >>
http://www.realoem.com/bmw/select.do
Old 07-20-2013, 11:17 PM   #29
markho
My Ride: 2002 325xi
markho is offline   Reply With Quote
Old 07-21-2013, 02:02 PM   #30
Kgoncalves
My Ride: BMW 325xi
