///M3 Forum
Old 07-17-2013, 09:53 AM   #1
vv23
My Ride: E46 M3
Issue with turner motorsport camber plates
Hey Guys
I bought a used E46 M3 with Bilstein PSS10 and turner motorsport camber plates in the front.
Problem i'm having is the camber plate bearings are worn and when I turn the steering wheel there is a grinding noise.
New plates are pretty expensive- anyone have any idea for a cheaper alternative? I could even use stock PSS10 top hats but I never got them with the car.
Thanks.
vv23 is offline   Reply With Quote
Old 07-17-2013, 11:33 AM   #2
etasport
My Ride: 03 M3, 87 e30s50
Did you have to assemble them before putting them in? There should be a washer between the spring hat and the bottom of the plate to allow it to turn smoothly. I have seen this happen with the results you are describing. I also did it on my own car with spec e30 plates from Ireland engineering. The correct washer took care of it. I would be surprised if the bearing actually went bad unless they were subject to a lot of water and rusted.
etasport is offline   Reply With Quote
Old 07-18-2013, 08:24 AM   #3
TurnerMS
My Ride: E30,E36,E46,E90,E92
Check your assembly. Make sure it is all correct.
Turner Motorsport
16 South Hunt Road
Amesbury, MA 01913
/ // Parts and Performance for BMWs
TurnerMS is offline   Reply With Quote
Old 07-18-2013, 01:09 PM   #4
vv23
My Ride: E46 M3
Just checked. Seems to be installed correctly.
Should I spray some grease into that area?
Any other suggestions?
Old 07-18-2013, 01:14 PM   #5
TurnerMS
Keep in mind, these plates use the factory bearing / spring hat. (See diagram above.) They do fail. Replacements are about 12.00 each. BMW Part # 31331090612
http://www.turnermotorsport.com/p-11...m3-e60-m5.aspx
Turner Motorsport
16 South Hunt Road
Amesbury, MA 01913
Old 07-24-2013, 03:31 PM   #6
vv23
My Ride: E46 M3
replacing the factory bearings fixed my problem. Thank you for your help
Old 07-24-2013, 03:33 PM   #7
TurnerMS
Great news.
Turner Motorsport
16 South Hunt Road
Amesbury, MA 01913
Old 07-25-2013, 05:39 PM   #8
vv23
My Ride: E46 M3
Nevermind noise is back.
Upon further inspection it looks like the bearings in the camber plates are seized. Is there any way to unsieze them? Are they replaceable?
Old 07-26-2013, 08:17 AM   #9
TurnerMS
Yes, replacement parts are available. Just give us a call. 800 280-6966 x 1
Thanks.
Turner Motorsport
16 South Hunt Road
Amesbury, MA 01913
Old 07-26-2013, 09:10 AM   #10
AudiEtr
My Ride: 330i
Great customer service!!
Turner Motorsports FTMFW!
AudiEtr is offline   Reply With Quote
Old 08-03-2013, 06:09 PM   #11
dee514
My Ride: M3
I just installed my TMS plates and love them. Great customer service!
dee514 is offline   Reply With Quote
