Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 06-19-2013, 11:28 AM   #161
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
S54 custom turbo setup
Originally Posted by Cipri View Post
My AEM doesn't read the vehicle speed, is this normal?
I know that the standard HPF kit uses the VSS coming off the transmission. I'm not sure if ur setup has that configured or not. In the AEMPro under sensors it is the VSS and input should be set at "spare speed sensor" I'm not sure what the pin on the AEM is?
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 06-19-2013, 11:39 AM   #162
being3
Modded ///Member
being3's Avatar
I just looked at ur tune... The VSS is configured properly.... U might want to check to see if its wired in properly.
Old 06-27-2013, 11:59 AM   #163
Cipri
My Ride: E46 M3 2002
Going full custom: 4" exhaust
More alumium custom to follow: expansion tank, surge tank, oil catch can.
ID:	513317   Click image for larger version
ID:	513318   Click image for larger version
Cipri is offline   Reply With Quote
Old 06-27-2013, 12:23 PM   #164
Think0rz
My Ride: 05 AW M3
can't wait to hear your exhaust setup I've been researching for a while about a custom exhaust setup for my car as I'm not satisfied with my current setup. great progress on your car looking forwards to some runs
Think0rz is offline   Reply With Quote
Old 06-27-2013, 03:36 PM   #165
being3
Modded ///Member
being3's Avatar
Very nice .... Keep up the good work...
Old 06-29-2013, 01:47 AM   #166
Cipri
Exhaust sound video:
https://www.facebook.com/photo.php?v=200879666733792
I will make a better video with my cam next weekend at the track.
Old 07-07-2013, 03:30 PM   #167
Cipri
Re: S54 custom turbo setup
Is it possible to have WOT gear change on our AEM V1?
Sent from my GT-I9505 using BimmerApp mobile app
Old 07-07-2013, 03:34 PM   #168
Commanderwiggin
My Ride: 1000rwhp Turbo M3
Exclamation
Yes
Old 07-16-2013, 01:57 PM   #169
Cipri
Just finished last tune, car runs amazing now, looking forward for the next 1/4 mile event.
I need to figure out VSS input pin for LC and how to configure WOT shift.
Results are on regular pump gas.
ID:	516747   Click image for larger version
ID:	516748   Click image for larger version
ID:	516749   Click image for larger version
Old 07-16-2013, 02:30 PM   #170
being3
Modded ///Member
being3's Avatar
Nice. U really persevered getting this done. hats off to u. Post the pinout for vss so we can hook it up too
Old 07-16-2013, 10:45 PM   #171
Twin_Turbo_S54
My Ride: M3
Cipri,
That fuel filter will decrease fuel flow.
You can get a fuel filter from Aeromotive and get the fuel flowing. Otherwise the pump will be blocked.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 07-16-2013, 10:49 PM   #172
turbotoy2791
My Ride: 04 m3
Great job!! How many pounds of boost are you running? What was the rwhp.
turbotoy2791 is offline   Reply With Quote
Old 07-17-2013, 09:23 AM   #173
Cipri
Originally Posted by Twin_Turbo_S54 View Post
Cipri,
Fuel flow is very good, I will not increase power on pump fuel.
Runing 20 PSI, RWHP are 700.
I don't have the VSS pinout, that's what I hope to receive from some ex-HPF guys...
Old 07-17-2013, 11:57 AM   #174
turbotoy2791
My Ride: 04 m3
Awesome!!!
Old 07-23-2013, 02:55 PM   #175
being3
Modded ///Member
being3's Avatar
Ok Capri I have some more info for the VSS.
On 40 pin black connector on BMW ECM pin 17 is output speed signal. I. Not sure if its from the transmission or wheel sensor. AEM VSS is B33 for Generation 1 ems.
Note: I have not tested this but should help get u started.
Old 08-19-2013, 01:19 PM   #176
Cipri
Same old problem which I can not fix:
Cold engine - everything is working perfect
Warm engine - if during cruising under 3000 RPM I push the clutch the RPM drops suddenly and engine stops. If I push only the brake and stay off the clutch until under 1200 RPM and then push the clutch, RPM drops to 500-600 -> comes back to normal and the engine doesn't die and idles ok.
This is anoying because in the city the engine dies if I try to down shift when driving slow...
Old 08-19-2013, 01:38 PM   #177
Commanderwiggin
Needs a shot of fuel before the idle motor kicks in.
Old 08-19-2013, 01:53 PM   #178
AMG-ETR
My Ride: S54B32 On Boost
Send a message via MSN to AMG-ETR
Give it a rev when you clutch in.
AMG-ETR is offline   Reply With Quote
Old 08-19-2013, 02:03 PM   #179
Cipri
What could be the problem?
I didn't had this issue before the engine rebuild with lower compression.
Old 09-22-2013, 11:03 PM   #180
being3
Modded ///Member
being3's Avatar
I'm wondering if its ur fuel trims for AIT... It could be tuned for cold and not add fuel when it gets warmer and then leans out.
