Old 07-24-2013, 05:55 PM   #1
Weste46
My Ride: 2001 330ci
Cooling system bleed
I just replaced my water pump, but I saw that the way the sticky says to bleed is to fill the tank until it pours bubble-free coolant from the bleed screw. I'm thinking these seems rather messy, and I would have to syphon excess out after I'm done.
I saw elsewhere that I could run the engine and just loosen the bleed screw until it spews coolant. I tried this way, but the bleed screw constantly spews vapor, for a long time. I don't ever get pure coolant coming out, only little squirts from time to time. Is this just air, and I haven't given it enough time to bleed? Or will this never spew 100% coolant mixture?
Thanks for any help!
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, AKG 95a FCA, 75d rear subframe, Powerflex 95a RTA, 95a RCA, ECS 88a diff., ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, open-loop EU2 tune, CAI, headers, x-pipe, minus ~180lbs.
Weste46 is offline   Reply With Quote
Old 07-24-2013, 06:02 PM   #2
Yewzer B Lewzer
My Ride: 2003 325i
Do it the right way as the sticky shows. You are risking your engine using the alternate method just to save a little mess?
^^Blue Ridge Parkway^^ '03 325i. '74 Jeep CJ-5. '93 Sailfish 170XL. '12 Westside SS Longboard. One of these four are sure to be running at any given point in time.
Yewzer B Lewzer is offline   Reply With Quote
Old 07-24-2013, 06:30 PM   #3
Weste46
My Ride: 2001 330ci
Re: Cooling system bleed
I didn't realize I was "risking" anything. Will do!
Old 07-24-2013, 06:40 PM   #4
Yewzer B Lewzer
My Ride: 2003 325i
Yep. Air pockets in the system can cause overheats which can warp the head and cause head gasket leaks. $$$$
Old 07-24-2013, 06:40 PM   #5
JamusMcFamus
My Ride: '02 325iT
It's dirty, yes, but it's infinitely easier than on, say, an E28 or an E12. In those cars, you bleed it while the car is on, so the fan is spewing it everywhere as you loosen the screw and watch for bubbles.
JamusMcFamus is offline   Reply With Quote
Old 07-24-2013, 06:40 PM   #6
Chrsb5
My Ride: 2004 330i
It's not much of a mess
Chrsb5 is offline   Reply With Quote
Old 07-24-2013, 06:42 PM   #7
aldeghij
My Ride: 2003 330i
Yeah, not messy at all. Just pour slllooooowwwly and all should be fine.
aldeghij is offline   Reply With Quote
Old 07-24-2013, 11:07 PM   #8
Weste46
My Ride: 2001 330ci
Right, I know. I'm saying I didn't realise that another way of bleeding wouldn't work just as well.
It's all done now, not too messy.
Old 07-25-2013, 06:37 AM   #9
Yewzer B Lewzer
My Ride: 2003 325i
Old 07-25-2013, 10:58 AM   #10
My Ride: Lexus
Yeah if you go slow it's not that messy. The most important thing is taking your time.
Old 07-26-2013, 11:35 AM   #11
hummer
My Ride: 2001 330CI
I'm going to say this ONE more time.
Remove the bleed screw.
Pour coolant into the tank until the level rises to the SCREW hole!
Stop and wait, as the coolant level in the hose will drop as air comes out.
Keep pouring and waiting until the level stops dropping.
DONE!:
This only requires a little bit of patience and makes zero mess!
If the car is level, you won't need to add but maybe a little more after one heat/cool cycle. If you like to raise the nose for some reason, it may get overfilled requiring some coolant removal. The float should not be pinned against the upper stop.
There is no need to spill a single drop!
