Old 07-24-2013, 06:52 PM   #1
elbee
My Ride: 2001 325I Sedan
Key Fob not locking/unlocking - actuator or GM5?
So, I had this issue once with my dad's e39. The key fob would not lock/unlock the doors. It was a fairly easy repair. I did it awhile ago so I don't remember the specifics, but the repair was done in the trunk.
The same issue is coming up on our e46 and based on the searching I've done, it's not as straightforward. It looks like it can be a problem with the actuator or the GM5 module. Both look like fairly involved DIY's. Is there a test I can do to determine which part might be the issue? I'm hoping to avoid an unnecessary DIY.
Thanks!
elbee is offline   Reply With Quote
Old 07-24-2013, 07:01 PM   #2
Snik
Snik's Avatar
My Ride: IR M3 Vert.
www.bmwgm5.com
Do you ride a sportbike?
Old 07-24-2013, 07:16 PM   #3
elbee
Thank you!
Old 07-24-2013, 07:16 PM   #4
jfoj
My Ride: 330CiC, M5, X5
Scott may chime in soon?
I think a few questions would be:
1. Is the problem only with a single door?
2. Do the interior lights come on, but the door not unlock?
3. Do you have the problem also unlocking the car using the central locking button?
4. How intermittent is the problem and does it appear to be heat related?
Old 07-24-2013, 08:30 PM   #5
SC4R27
My Ride: 03 325i Sport Pckg
my key just stopped working on all doors and trunk. the interior lights also do not turn on. Sometimes if i shake the key (i do not hear anything inside) and then press unlock it will work. I think its broken from being dropped. Should i get a new key?
'03 325i ZSP
'06 325xi
SC4R27 is offline   Reply With Quote
Old 07-24-2013, 08:32 PM   #6
Snik
Snik's Avatar
does the central lock button work if say you try to get in and the windows are down.
does it seem to do it more in the hot day rather than the cool night?
Old 07-24-2013, 08:42 PM   #7
SC4R27
No they don't and the temperature does not change the outcome. I was hoping all it needs is a new battery
'03 325i ZSP
'06 325xi
Old 07-24-2013, 08:54 PM   #8
Snik
Snik's Avatar
yeah, doesnt sound like the GM5
Old 07-24-2013, 09:17 PM   #9
scottjoh
My Ride: '99 323i & '02 540i
CHIME!
Bad key. Get it repaired or buy a new one. It's up to you.
So the SAME issue is happening with your E46 which from what you wrote about the E39 problem I see that you are having issues "The key fob would not lock/unlock the doors." This is not a GM5 or actuator problem. Sounds more like a key fob, key sync or FZV antenna amplifier problem.
scottjoh is offline   Reply With Quote
Old 07-24-2013, 09:27 PM   #10
jfoj
Make sure you call around to the dealers and ask for the key by part number.
Master key/keyfob part number - 66126955750 (BMW list price is showing $166.29 last I checked, some dealers will sell for as low as $124.72).
Old 02-08-2014, 05:06 PM   #11
Twizted328i
My Ride: 328i saloon e46
Hi buddy I have these problems not key fob as have tried two what is your suggestion if answers to above questions are yes?
Twizted328i is offline   Reply With Quote
