Thread Tools Search this Thread Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Old 07-24-2013, 09:47 AM   #61
stevenluczynski
My Ride: Is Steel Blue
Turn your A/C on, if its broken fix it.
stevenluczynski is offline   Reply With Quote
Old 07-24-2013, 02:18 PM   #62
Knight
My Ride: '05 330Ci | '01 325i
A/C on, try not to go too far off the ambient temperature and set the blower direction to include both the front and the dash. This car does fog up more than others I've owned/driven.
Knight is offline   Reply With Quote
Old 07-24-2013, 02:36 PM   #63
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Need help without car for when it rains
^ yup e46's do fog up a lot.
OP just turn on the a/c
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 07-24-2013, 02:43 PM   #64
jdstrickland
My Ride: '94 325iC & '00 323i
Originally Posted by DMahoney View Post
2201 325ci (coupe).
My problem is thAt when it rains, the windows fog up like crazy. I can't put my windows down because the rain likes to come in on the car on an e46 more than any other car I've been in lol..
Anyone ever custom make rain guards for the coupe? Or know of anyone? They aren't on the market because there's no actual "door frame. Just the door; as most of you already know.
I'd like to leave windows down sometimes when it rains not only for the fog but also because the defroster gets a little warm & sweaty.
I need help with this :/ Any help or ideads would be greatly appreciated. Thanks
Turn the ventilation system on and never ever under any circumstance turn it off.
If you have windows fogging up, then you have stagnant air in the cabin. The more stagnant that it is, the greater the fog.
You can fight the moisture on the inside by setting the AC on. Air conditioning is a dehumidifier, and the fog is humidity. At first, wet the airflow to the defrost vents so there is lots of dehumidified air on the windshield, once the windshield clears, then you can set the air to blow out where ever you want, but keep the AC on. You can run the heater up a little if the AC is too cold.
Old 07-24-2013, 02:45 PM   #65
jdstrickland
You can set the temperature separately from the vent selection, so it is false to say that the defroster is toasty, the defroster can be as cold as the dash vents if you set the controls properly.
Old 07-24-2013, 03:29 PM   #66
jfoj
My Ride: 330CiC, M5, X5
Do the windows fog up when the car sits?
You may have an water leak in the interior as well?
Old 07-24-2013, 03:49 PM   #67
Beamin-Bajaj
My Ride: 2002 325xi
Lol I thought i was alone with this car fogging up with the rain...putting the a/c on and dealing with it for 2 years strong
Beamin-Bajaj is offline   Reply With Quote
Old 07-24-2013, 04:28 PM   #68
jfoj
For the 4/5 door owners, rear door vapor barriers leak ALL the time and add additional moisture in the car that can be an issue when it rains.
Sunroof drain and cowl leaks are also common.
Need to first make sure there is no excess moisture getting into the car, this will just make it worse when it rains for foggy windows.
Old 07-24-2013, 05:26 PM   #69
WDE46
My Ride: '13 128i, '04 330Ci
Basically you just need moving air over the surface of the windows. Or you can heat the glass. Turn your AC on. With wipers on, I'm pretty sure our cars automatically turn the windshield vents on.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 07-24-2013, 09:04 PM   #70
wildirish317
My Ride: 2004 325Ci vert
Unless you have the top down.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 07-24-2013, 09:46 PM   #71
jdstrickland
My fan has been on low for 8 years, unless my math is wrong, then it's been 9 years, and ignores the times it has been higher than low. I never ever under any circumstance for any reason turn the fan to off. Not ever. Even with the top down.
Old 07-24-2013, 09:48 PM   #72
WDE46
why?
Old 07-24-2013, 10:12 PM   #73
wildirish317
Whenever I put the top down, I turn the fan off. What's the point of trying to condition the world from your car? If the top is up, the HVAC system is on Auto.
Old 07-25-2013, 12:00 PM   #74
daki_bmw
My Ride: 330Ci
Originally Posted by WDE46 View Post
why?
Turning it completly off closes all the open flaps. Turning it on next time opens flaps again.* I don't want/need to do that to my 5 or so electric motors for flaps. If I need particular flap opened/closed, I do it manually. But air flow is so low (power usage also) at the lowest setting, that shutting it off puts unneeded "strain" to my 12yo electro-mechanic flap system, which can crap on me anytime.
*At least that's how my HVAC is programmed to operate.
daki_bmw is offline   Reply With Quote
Old 07-25-2013, 12:36 PM   #75
Zell
Zell's Avatar
My Ride: so turbo wow
http://www.amazon.com/BMW-Original-W...4770194&sr=1-1
Old 07-25-2013, 01:56 PM   #76
jdstrickland
why?
Why not? I hate a stuffy car.
If I got into your car and the fan was off, I would turn it on just to have moving air in the cabin. Just a habit I suppose, but one I insist on maintaining. Perhaps I'm overly anal about this, but I was overjoyed, seriously, in the late '70s to early '80s when they made the ventilation system fan remain on at all times. I don't know what changed to have the car makers put an OFF selection back into the life support systems, but I can clearly remember driving cars that the fan could not be set to off.
Old 07-25-2013, 07:46 PM   #77
Sweetness
My Ride: '01 325i
The fix is simple. Rain-X the inside and the outside of the car. No more fog. Never happened to me since doing that.
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 07-25-2013, 08:54 PM   #78
jdstrickland
I just turn the AC on hi for a few minutes, then turn it to lo and set the heat to a comfortable level. It's free and I have a button that does the hard part of the job for me.
Old 07-25-2013, 11:01 PM   #79
David McMahon
My Ride: '99 E38 740iL
My car steams up so quickly it feels a bit dangerous, Hitting A/C and windscreen vent does sort it quite quickly, but I'm going to check out the solutions mentioned above.
David McMahon is offline   Reply With Quote
Old 12-11-2014, 11:17 AM   #80
Ceric
My Ride: 2005 BMW 325i
Car fogging up like crazy in winter snowstorm.
It's snowing here right now, a crazy amount of snow. So naturally I decided to go out and have some fun in a huge private parking lot. And this brought up an issue I had a problem with in the summer, but I simply attributed it to the very high humidity in Toronto's summertime.
However, today it was -5*Celsius outside, and snowing. The entire drive all of my windows were fogging up like crazy no matter what I tried. It was so bad that I felt unsafe driving. THe only thing that helped a bit was setting the HVAC system to maximum heat and blasting all vents at full speed while having the HVAC set to take in outside air.
Meanwhile - all the other cars around me had windows that you could clearly and easily see through. What in the world is happening? I feel like I am inside a hermetically sealed room when I step in to the car. I just can not get rid of the humidity/condensation that seems to happen.
Ceric is offline   Reply With Quote
