///M3 Forum
Old 07-25-2013, 01:56 PM   #1
Ballerbrian4u
My Ride: 2004 BMW m3
How much oil for a oil change.
Going to Do a oil change today. I want to know exactly how much oil to put? 5 and a half and check the levels? Or 5 and a quarter Bottle?
Ballerbrian4u is offline   Reply With Quote
Old 07-25-2013, 03:20 PM   #2
stolidog
My Ride: 2004 M3 6spd
5.5L and check the level. I find that mine will take the full 6 and be right at the top marker.
stolidog is offline   Reply With Quote
Old 07-25-2013, 03:30 PM   #3
Ballerbrian4u
So add 5 and a half and check levels? Should be up to the top of dip stick?
Old 07-25-2013, 04:40 PM   #4
epfenninger
My Ride: 2001 325xi
epfenninger is offline   Reply With Quote
Old 07-25-2013, 04:43 PM   #5
JJR4884
My Ride: BMW
Originally Posted by epfenninger View Post
6.9 quarts
open your eyes dude, this is the m3 forum... if anyone takes your advice you are going to cause thousands of dollars worth of damage
JJR4884 is offline   Reply With Quote
Old 07-25-2013, 05:32 PM   #6
epfenninger
My Ride: 2001 325xi
**** my bad, I'll delete that
Old 07-25-2013, 05:34 PM   #7
JJR4884
My Ride: BMW
Old 07-25-2013, 07:39 PM   #8
Ballerbrian4u
Guys when I turn the key to the 3rd position it say service engine soon. What is that light? It is not there when I am driving only when I turn the key to the 3rd position!
Old 07-26-2013, 10:15 AM   #9
DSilk56
My Ride: M-3 Convertible
It's an indication that a fault code has been tripped, usually with regard to the emissions control systems. It should ALWAYS turn on when the key is in the pre-crank position, as this shows that the light is functioning. If it comes on or stays on when the engine is running you will need to have your codes read.
DSilk56 is offline   Reply With Quote
Old 07-26-2013, 03:01 PM   #10
Ballerbrian4u
So it normal for it to STAY on in the pre-crank position?
Old 07-26-2013, 05:31 PM   #11
stolidog
Pretty sure that's normal, though I cant say for certain without checking my own car.
Old 07-27-2013, 12:34 AM   #12
Ballerbrian4u
If you can check and get back to me please!!!! I would love you forever!!
Old 08-01-2013, 12:49 PM   #13
stolidog
Finally got a chance to check this. Mine stays on.. so I'll go with "it's normal". Final answer.
Old 08-01-2013, 09:27 PM   #14
Slyde
My Ride: 2001 M3 TiAg
Mine is on pre-ignition and immediately turns off upon starting.
Slyde is offline   Reply With Quote
