Old 07-26-2013, 10:05 AM   #1
bmech211
My Ride: '06 Carbon Black M3
Stock S54 Intake Plenum for Boost
I've searched and searched, both Google and other forums, but can not find any definitive answers as to specifically where a failure occurs on the stock S54 intake plenum due to over pressurization. Is it a catastrophic type failure such that the whole plenum basically blows a hole in it, or is it more like splitting at the production seams?
Any ideas on the best approach at reinforcing failure prone areas to handle between 14-16 psi boost?
Thanks..
bmech211 is offline   Reply With Quote
Old 07-26-2013, 11:14 AM   #2
dallasberry
My Ride: ///M3
In m opinion I Would just buy one designed to handle boost. Why risk it? With the amount of time and money to make the stock one stronger, I'm sure you can buy one designed to handle the pressure.
Custom Turbo Build By Lab22
815whp @ 625wtq 27psi E98
dallasberry is offline   Reply With Quote
Old 07-26-2013, 02:30 PM   #3
Commanderwiggin
My Ride: 1000rwhp Turbo M3
I don't even think it will handle 6-8psi safely.
Old 07-26-2013, 03:32 PM   #4
mike@maximumpsi
My Ride: 02M3T
We ran 9psi with a stock one and it failed. We then modified and reinforced one and it held together. The next issue is keeping it clamped on at that boost level.
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 07-26-2013, 03:48 PM   #5
mkodama
mkodama's Avatar
1. The stock plenum wasn't designed for any vacuum or boost.
2. Do a rough calculation of how many square inches there are on just the top surface of the plenum. Multiply that number by just 10 psi; the product will be how many pounds of force on that surface.
3. Realize you're putting an absurd amount of stress on some plastic that wasn't designed for anything other than separating some filtered air from unfiltered air.
Old 07-26-2013, 04:09 PM   #6
Twin_Turbo_S54
My Ride: M3
It will leak.
It wont have a proper blow off valve installation.
Just buy an intake manifold.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
