Old 07-21-2013, 12:24 PM   #1
Curious330
My Ride: 330i
Need Some Serious Help!
Hey detailing fanatics! I really need some help and advice on detailing my car. Some of the questions are going to be geared towards how much would it cost for me to have a professional detailer fix, or myself. The first questions are going to be geared towards what can I personally do to fix it.
So after purchasing my car, I did a pretty extensive detail. I washed it, dried it, clayed it, washed it, dried it, compound and then a wax. Well when compounding that stuff seems to have gotten everywhere... I need some help on how to remove this and get my pieces back to the black they once where. Here are some photos of the pieces I need to get the compound off of. Still here after 3 washes later. Bigger pictures can be provided if need be.
Door Pillar:
Sunroof Trim: (Sunroof also "sags" in the back now and is not flush with the top of the car... My motor was broken when I purchased it but I do believe this is a new occurrence, any ideas?)
Body Trim:
Underneath the body trim...:
So that basically concludes as to what I would like to get taken care of immediately. It's rather annoying...
Next I will cover what I may be able to do myself or need a possible detailer for.
On the driver's side pillar there are these teenie tiny rust looking chips. Also there is compound on this trim as well that I would like to remove:
- - - Updated - - -
Then there's these chips on the hood:
And this little paint crack on the rear bumper:
Thanks guys!
Curious330 is offline   Reply With Quote
Old 07-27-2013, 07:16 AM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Magic eraser will work on your trim, between the doors on the matte finish paint (be gentle). For the edges and sunroof trim, try a toothbrush with soft bristle.
See me in NYC in June!
Ha! Ridgehill, Yonkers, June 8, 8 p.m. & Broadway Comedy Club, Sat., June 10, 6 p.m.
dmax on Facebook
Mangofy your E46!
Old 07-27-2013, 07:48 AM   #3
Foxtrot_Uniform
My Ride: 325Xi
Use toothpicks and Q-tips to get the old wax out of tight areas. Don't eraser your trim... Get some solvent and take the wax off the trim.
Foxtrot_Uniform is offline   Reply With Quote
Old 07-27-2013, 09:26 AM   #4
scrace
My Ride: 03.5 M3
Do not use a magic eraser on your trim unless you plan on applying a UV protectant afterwards. It will just end up looking worse after a couple months because you are removing whatever coating is on the trim to protect it.
You wan o be using a chemical cleaner not an abrasive (think like sandpaper).
2001 Topaz Blue 325Ci 64-120k miles SOLD
2003.5 Silver Gray M3 70k miles
scrace is offline   Reply With Quote
Old 07-27-2013, 09:32 AM   #5
dmax
dmax's Avatar
Been using it for years with no ill effects...it's clean and black and stays that way as long as I don't get wax or polish on it. I think it's all the same material through and through, so no coating on it that I know of.
dmax on Facebook
Mangofy your E46!
Old 07-27-2013, 06:55 PM   #6
Curious330
My Ride: 330i
What would you suggest I use then? I haven't tried it on the trim around the car but the IPA did not work on the door panels.
Old 07-28-2013, 07:51 AM   #7
scrace
My Ride: 03.5 M3
http://www.detailingworld.co.uk/foru...d.php?t=103881
Is my best suggestion with the given information.
Old 07-28-2013, 12:27 PM   #8
Curious330
My Ride: 330i
I like the results. Aren't our door panels painted though? If this is to be kept off paint would it still be okay?
Old 07-30-2013, 05:34 AM   #9
scrace
My Ride: 03.5 M3
Only use it on trim, follow the direction on the bottle.
Old 07-30-2013, 11:54 AM   #10
Curious330
My Ride: 330i
How do you propose I resolve the issue on the door panels?
