Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > California
California
Northern California Southern California
Thread Tools Search this Thread Rating: Thread Rating: 230 votes, 4.59 average.
Old 08-01-2013, 08:00 PM   #339741
DJ RaMiN
My Ride: 02 325I,03 M3
I should probably do something about the coolant in the van. It's been looking quite nasty, for a while now.
have you find the leak yet?
BMW driver complaining about $250? That's lunch!
Originally Posted by 323ci newbie View Post
Man, you all is best!
Here is my Facebook page, Like me maybe:
https://www.facebook.com/DJRaMiNUS
DJ RaMiN is offline   Reply With Quote
Old 08-01-2013, 08:02 PM   #339742
DJ RaMiN
Blah... I'm frustrated with the van. So I think water vapor doesn't just mess up the throttle position sensor, but it permanently kills them. Also my idle air control valve is sticking now. So time to order a new throttle position sensor, and a new idle air control valve. I can put the idle air control valve on the engine right away, but I'm not sure what to do about the throttle position sensor because of how quickly and easily they can be killed.
Currently the throttle position sensor reads 10% throttle when I'm not pressing the gas, and reads way higher than it should in the middle of its range of travel, making the transmission hold onto gears much longer than it should. The idle air control valve just makes excessive noise when I turn the car to the on position, and after a bit of driving, sticks and won't let the idle go below ~1600 RPM.
This is what I get for leaving these items attached when I cleaned the intake manifold. Thanks GM for not making your engine parts resistant.
I can help you if you need help working on the van.
Old 08-01-2013, 08:11 PM   #339743
mkodama
mkodama's Avatar
Not sure if there is a leak or not. The van uses an overflow tank instead of an expansion tank, so I'm not sure if it's actually running low or if it's just sloshing around and spilling out as I drive.
Old 08-01-2013, 08:19 PM   #339744
mkodama
mkodama's Avatar
Excellent, you can buy me a delphi throttle position sensor, delphi idle air control valve, and some Prestone radiator flush!
jk
I'm about to order all that right now.
The hard part is you actually have a job, so that makes your free time pretty limited unlike myself. :\
Old 08-01-2013, 08:38 PM   #339745
DJ RaMiN
yea, its weird. last time I went under the van to install that sensor thing. I checked to see if I can see anything leaking, but couldn't find anything.
Old 08-01-2013, 08:43 PM   #339746
DJ RaMiN
jk
lol
yea, well, do your stuff and if anything left I'll help you on my days off.
Old 08-01-2013, 08:52 PM   #339747
DJ RaMiN
Daniel:
http://sfbay.craigslist.org/sby/pts/3973115035.html
Old 08-01-2013, 09:02 PM   #339748
DJ RaMiN
RGRs
http://sfbay.craigslist.org/sby/pts/3968694128.html
Old 08-01-2013, 09:09 PM   #339749
mkodama
mkodama's Avatar
Not a good deal, average to expensive.
Old 08-01-2013, 09:09 PM   #339750
mkodama
mkodama's Avatar
I do miss my RG-Rs though...
Old 08-01-2013, 09:15 PM   #339751
325inthe510
My Ride: 152ci of madness
jk
I'm also closer to teh warehaus
325inthe510 is offline   Reply With Quote
Old 08-01-2013, 09:16 PM   #339752
325inthe510
Those thule roof racks too, that guy wants OEM BMW money for that.
And I simply don't have the money for something as superfluous as roof racks right now
Old 08-01-2013, 09:23 PM   #339753
DJ RaMiN
wish this guy was here :/
http://forum.e46fanatics.com/showthread.php?t=987404
Old 08-01-2013, 09:32 PM   #339754
mtnbound
Town Clown
My Ride: 330Ci Vert, 325iT
Yeah, that's what I was saying. Anything 12-8mm should be avoided. 12's starting varying a little bit whether they fit or not based on the chamfer of the wheel's centerbore.
Bay Area Top Dropper
Orient Blue 330 Ci Vert
mtnbound is offline   Reply With Quote
Old 08-01-2013, 09:32 PM   #339755
mkodama
mkodama's Avatar
Weighed myself the other day, and I was at 151 pounds.
I've been holding back on proportions and went for a run today.
/fat girl diaries
Old 08-01-2013, 09:34 PM   #339756
mtnbound
Town Clown
Thank you sir. well, I saw people do that to their stock intake housing. they just made a hole on the bottom of the housing for the tube. then I decided to do it for mine.
Is that funnel piece just a regular funnel?
Old 08-01-2013, 09:41 PM   #339757
mkodama
mkodama's Avatar
Anybody need a brand new Epson CX4450 all-in-one printer? $20?
Old 08-01-2013, 09:44 PM   #339758
DJ RaMiN
I got this guy:
http://www.amazon.com/Spectre-Perfor...=air+duct+tube
Old 08-01-2013, 09:45 PM   #339759
DJ RaMiN
Miles, good candidate for our project?
http://www.ebay.com/itm/BMW-E46-M3-O...item43bc574f55
Old 08-01-2013, 09:45 PM   #339760
DJ RaMiN
I do need one...why so cheap?
>implying the e9x is good, '02-'05 grandpas, '06 gods, '07 og's, '08 n00bs, '09 working class, '10 plebeians, '11 master race, '11 peasants, class of, norcal, norcal gen chaaaaat, norcal general chat
Rate This Thread
