Old 06-20-2013, 09:55 PM   #1
lovemy330ci
My Ride: 03 M3, VF570 StgII
best tune for catless headers for m54b30
does anyone know the best option for tunes for this set up?
lovemy330ci is offline   Reply With Quote
Old 06-20-2013, 09:58 PM   #2
330CSL
My Ride: 03 330ci
I Have AA but it has been shown that the Shark dyno's higher
330CSL is offline   Reply With Quote
Old 06-27-2013, 09:49 PM   #3
jdjg
My Ride: e39, m52tub30
yes, the Euro Specs DME mapping.... with the cat less setup.....
jdjg is offline   Reply With Quote
Old 06-29-2013, 07:37 PM   #4
wallyworld
My Ride: 2003 325i 4dr sedan
Is the Euro Specs DME mapping how BMW's in europe are tuned out of factory?
I've heard of a euro tune, is this what you speak of?
wallyworld is offline   Reply With Quote
Old 07-31-2013, 10:45 PM   #5
jdjg
yes....
BMW Euro map... no more Check Engine light, no mor O2 sensor after cat, no more cat....., also you will gain around 5hp vs BMW US map....
Old 07-31-2013, 10:48 PM   #6
wallyworld
Re: best tune for catless headers for m54b30
yes....
is there a easy way to do this diy? or is there a better tune out there for less?
Sent from my SPH-D710 using BimmerApp mobile app
Old 07-31-2013, 10:58 PM   #7
jdjg
yes, using the Winkfp program...
Old 08-01-2013, 12:26 AM   #8
lovemy330ci
how can i get this euro tune
Old 08-01-2013, 01:16 AM   #9
daniel_f.
My Ride: 330iC
depending on your hardware (MS43!), you have to choose the right software (ZSBN) in winkfp.
you can digg out which software to use, when you take the last 7 digits from the part number you want.
so for my 330iCA i wanted the part number "12 14 7 545 671" as its stated for use in EU2 Version or without EOBD.
the highlighted number is the ZSBN which i flashed in winkfp. make shure to disconnect the lambdasensors (+SAP) you dont want to be monitored before flashing the software.
during the flashing procedure, the dme will look what kind of hardware is connected and will therefore monitor that hardware.
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 08-01-2013, 09:55 PM   #10
330i4me
My Ride: 01 330i
"AUTOTECHNIC" in connecticut can do it for ya, mines done and i went through emissions inspection and passed
330i4me is offline   Reply With Quote
Old 08-01-2013, 10:34 PM   #11
jdjg
the highlighted number is the ZSBN which i flashed in winkfp. make shure to disconnect the lambdasensors (+SAP) you don´t want to be monitored before flashing the software.
the right software daniel??? I guess you can use the software you want....
for example, I bought an used US Spec MS43 DME, and I search in the realoem, what are the software for a e39 530 euro spec, and I have several options, so I put all the options in my US Spec MS43 DME without a problem.....
Old 08-02-2013, 12:27 AM   #12
Llink78
My Ride: 2002 330i
Need EU2 done soon. Can't find anyone in western Ny
Llink78 is offline   Reply With Quote
Old 08-02-2013, 01:17 AM   #13
daniel_f.
My Ride: 330iC
The "right" = the one which corresponds to EU2
i tested a different version yesterday and even without any lambda plugged, it showed me "Abgasvariante: Kat" which means that the catalytic converter is still wanted and even the lambdas where monitored. the software was stated for use at EU2, EU3 without EOBD and even SA199 (using with leaded fuel).
So i switched to the stated 7545671 and now inpa says "Abgasvariante: Kat-Vorbereitung" and now there is no error code without the lambdas.
obviously you can use software from E39, Z3 and e46, but each has slight changes in the mapping.
Siemens MS42 wiki!
Siemens MS43 wiki!
