Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 42 votes, 4.71 average.
Old 08-06-2013, 06:35 PM   #581
linom3
My Ride: M3
4 months and no problems! Rides like new.
linom3 is offline   Reply With Quote
Old 08-06-2013, 07:27 PM   #582
bad91teg
My Ride: 2000 323i
installed coilovers with new shock/strut tops. front sitting a touch higher than stock ? (adjuster pre set from suspension source is 3/4 down.) but still a touch higher than stock ? DOES THE PIN STICKING OFF SIDE OF STRUT GO DOWN TO TOP OF BOTTOM CLAMP ? thank you !anybody who can help me out ?
bad91teg is offline   Reply With Quote
Old 08-06-2013, 07:39 PM   #583
bad91teg
My Ride: 2000 323i
just read thru some and see the pin sticking out the side of strut goes down into crack of clamp ..did that but still seems as if its stock hieght in front still
Old 08-06-2013, 07:46 PM   #584
CharlzO
My Ride: 2000 328ci
Re: *Street Edge Coilovers Review *
It does go in, make sure that is fully seated all the way in. If you can, remove the wheel, put the car on a jack stand. Loosen the pinch bolt, and jack up the control arm to make sure it's seated all the way. It also takes a little bit to settle afterwards too but I would think that you'd notice at least a little at first over stock.
CharlzO is offline   Reply With Quote
Old 08-07-2013, 11:42 AM   #585
Sales@TSS
Sales@TSS's Avatar
My Ride: 1995 BMW E36 325i
Sounds like you do not have the housing sitting in the hub correctly.
Sales @ The Suspension Source
www.thesuspensionsource.com
5654 E. Westover #112
Fresno, CA 93727
1-888-230-1288
Sales@TSS is offline   Reply With Quote
Old 08-07-2013, 04:40 PM   #586
bad91teg
My Ride: 2000 323i
ok could you explain correctly? some instructions with the kit would of helped. are u saying the strut housing is not in the clamp correctly. the pin slid down into the crack of clamp and bottomed out. will not go further down ? please lmk asap
Old 08-07-2013, 06:31 PM   #587
bad91teg
My Ride: 2000 323i
got it .lowered collar all the way down. car sitting low. actually if it settles a little i might raise it up . everything is in ..just got to get strut bolt tight at top before test drive.
Old 08-09-2013, 07:56 PM   #588
bad91teg
My Ride: 2000 323i
test drive complete ..all is good . installed new top stut/shock tops with them,no clunks ..super happy .i recommend them .
Old 08-09-2013, 11:46 PM   #589
CharlzO
My Ride: 2000 328ci
Awesome to hear ya got it seated! Still loving mine 1k miles after install
Old 08-11-2013, 01:22 PM   #590
ashburn
My Ride: 2000 328i
Hi Kris, I just ordered a set, and was wondering if I would need wheel spacers. I am running 16x7.5 et30 wheels.
ashburn is offline   Reply With Quote
Old 08-12-2013, 07:07 PM   #591
bad91teg
My Ride: 2000 323i
hey thanks for your help . cool of u to help .thanks again
Old 08-12-2013, 07:20 PM   #592
CharlzO
My Ride: 2000 328ci
You were on the right track, I'm sure you would've gotten it either way As much help as this forum has been to me, I try to offer what I can too
Old 08-18-2013, 07:01 PM   #593
bad91teg
My Ride: 2000 323i
fronts all the way down.rear about half way down. on 19" wheels
Old 08-18-2013, 09:28 PM   #594
Soflo_cars
My Ride: 04 325i sedan
bad91, what front bumper are you running?? I want a lip
Soflo_cars is offline   Reply With Quote
Old 08-18-2013, 09:54 PM   #595
brickhaus
My Ride: 328ci
So where can i order a set of these? seem to be the best bang for the buck for coils. better than racelands it appears
brickhaus is offline   Reply With Quote
Old 08-19-2013, 04:56 PM   #596
bad91teg
My Ride: 2000 323i
its just a ebay lip. but im so happy with it.it fit perfect ,its urathane type so it can take a beating. heres a pic.it should be easy to find .if not ill send u a link if u need it.
Old 08-19-2013, 05:10 PM   #597
CharlzO
My Ride: 2000 328ci
Just click The Suspension Source links in Kris's signature, it'll take ya there.
Old 08-19-2013, 05:19 PM   #598
Sales@TSS
Sales@TSS's Avatar
Click link or give me a call/text 559-790-3287
Fresno, CA 93727
1-888-230-1288
Old 08-28-2013, 11:35 PM   #599
BmwSonora26
My Ride: Bmw325ci
Here is mine about 5months in
BmwSonora26 is offline   Reply With Quote
Old 08-29-2013, 12:23 AM   #600
Linx
My Ride: '02 BMW 325iT
Attachment 524093
Looks good. Few questions though. Is that at the lowest setting? Any issues so far? Though I know these are not for the track but how do they perform compared to stock sport suspension?
Linx is offline   Reply With Quote
Rate This Thread
